@Greek_m43 : You should check the Lanparte Baseplate listed on the deals, very very good quality, and comes with two 30cm rods. You seem to have a decent tripod, but don't forget that the stiffness of the legs and head is the key to get stable shots.
@Greek_m43 : I use legacy lenses like yashica ML 50mm that are very similar to FD lenses (in size) and everything fit well on the 30cm rods. I can send you some picture if you want to get an idea.
@tonalt True. In your setup, one can also place Varavon Lens Support upside-down on the top rails.
BTW, is there just one side bracket on the left? If so, the system might still have too much flex in it. May I suggest a cage with at least two side brackets, either on the same side or opposite each other.
@mo7ies yes there is just one, luckily I have one more. But it's tricky to place them correctly and at the same time get access to SD-card, open display to left, enough space for FF etc..
I knew there was a reason to order multiple gini rigs.. I got enough parts to build the ultimate rig ;)
I finally bought a very "decent" tripod kit, Manfrotto 504HD + 535K Carbon Fiber legs. Very pricey but I chose to only buy one good tripod, not 3 or 4 until I find something decent... I'm very happy with it, the shakes while pulling focus are only noticeable on ETC mode, panning and tilting are smooth.
