Do you always get "FILE NUMBER EXCEED LIMIT" after a successfull span?
  • ... or is it just my settings/card? (GH2, Sandisk 64GB 95MB/s, Sedna B)
  • 6 Replies sorted by
  • You have to record a short clip before you shut the camera off to prevent this, I think if you search for "file number exceed limit" you will find a few discussions of this.
  • I did find that, just wonder if this is card/settings specific or not.
  • I can say for sure that this "FILE NUMBER EXCEED..." thing does not always happen after a successful span, in fact I have seen it only a few times with many "spans" done without this symptom.
    But what exactly this phenomenon depends on remains a mystery to me.
  • I saw it once - and only when I'd filled the card, not replaced it with another. I wondered about the ambiguous syntax here: I'd have expected "File number exceeds", meaning the filename is too high, or else "File number exceed" meaning there are too many files.
  • I got this error the other day while shooting with FM2.0. The weird thing is, I had just formatted the card, switched the camera off then on again, and still got the same error. I tried formatting AGAIN, but the error persisted. I switched to a smaller card. Mystery indeed.
