Has anyone tried to change the spring in the FC-04H head they bought though PV? When I bought the head I was shooting mostly stripped down, with only a mic, but now I find myself rigged up almost all the time with monitor, rails, ff, etc. So I'm pondering either buying a different head and using this one for my lighter set up or swapping out the spring. I have no idea where to even start for the swap out. Anyone with some guidance on how or whether it's worth the hassle?
@Vitaliy_Kiselev Thanks, I'll give it a try.
You need to carefully partially disassembly the head.
Remove the top. Later use the side without any knobs.
Spring is located directly inside.
