I love my GH1, I love LPowell's Max Latitude hack. I need to shoot something for a client, and it needs to cut together with other 30p footage - is there a problem with changing the frame rate in AVCHD to 30 frames? Will the chip handle that? Or should I switch to his maximum reliability hack? Either way, it has to be 30p (I'll switch back to my beloved 24p max latitude hack afterwards).
Also, do I have to switch back to the factory settings before installing a new hack, or can I just bump up the new hack to a higher version number? Thanks in advance for all your help!
For AVCHD 720p30 on the GH1 I recommend using the Fast Action 3-Frame GOP patch::
Thanks, but is 30p 1080 possible? The A camera is shooting in that format.
He says that's 720, not 1080.
Ok thanks!
