Pre-hack, I barely ever saw moire with my GH2 + Panny 14-45mm, but I seem to get more moire with the current hacks, inc Canis Majoris.
I mainly see the moire on the widest setting at around f5.6. It's driving me mad, but can't work out why it's doing this.
Is it the lens/hack/optical stablisation? Any hints would be greatly appreciated, as I don't want to retreat to factory firmware settings!
Cheers.
This sample is with the Mysteron hack, panny 14-45mm (at 14mm) at f5.6. The moire is more visible on playback:
http://www.mediafire.com/?p77b1co2jvkdf18
(the above video is the original mts file rewrapped as an mp4: no re-encoding)
Please see jpg attached with the areas circled where the moire is noticeable.
Hope you can help!
That looks like aliasing, not moire. What were your settings? The lines you are referring to in the image are all relatively high contrast lines, which can suffer aliasing. But what can make it worse is sharpening in camera.
Some people have noted that in camera sharpening seems to be worse when using native lenses.
After seeing how bad the moire and aliasing was on the 5DMK2 and my Pentax K5 the GH2 is a revelation. Has anyone been able to confirm whether Panny lenses cause in camera sharpening to be applied regardless if sharpening is turned down to -2 in the menu? I have not had any noticeable moire or aliasing issues using the GH2 with my Pentax glass.
