                  Pro version of same thing
Not very cheap stuff
http://www.bhphotovideo.com/c/product/842095-REG/Beachtek_DXA_SLR_PRO_DXA_SLR_ACTIVE_DSLR_ADAPTER.html
Is there any real benefit to using a Beachtek type audio adapter, over using something like the Tascam DR-100 feeding audio into the GH2 via the line-out jack? Since the DR-100 has dedicated line-out and headphone jacks, one wouldn't need to use a splitter or anything. And the added recording feature / built-in microphones of the DR-100 seem to put it well ahead of Beachtek audio adapters, while costing less.
The only possible drawback I can think of is that it eats through batteries a bit faster, but I'd just be powering it off of a high-mAh battery pack on my rig, anyway.
It seems like it's an easy decision, but am I missing something here?
@Sangye there are a few things that I can think of that make a preamp like the DXA-SLR better compared to recorder such as the Tascam DR-100
However, the DR-100 has some benefits of it's own:
Did I miss something? The Beachtek DXA-SLR output delivers 0dBu maximum gain, correct? This is is way too hot for the GH2´s inputs. In the audio hacks discussion, we found out that -27dBu is the sweet spot for the 203-AGC setting, which provides the least of amplification. You will need a voltage divider/damping pad for using the Beachtek with the GH2
Here's a comparison of the Beachtek versus the Juicedlink PreAmp.
I have the original Beachtek DXA-SLR that I bought with my GH2. I just saw this article about the beachtek ultra and the GH4 http://beachtek.com/panasonic-gh4-audio-performance/
Is it worth the upgrade to purchase the Ultra? If I lower the GH4 to -12 with limiter on, will I still get good audio quality with my original DXA-SLR? I'm using a Audio-Technica AT875R shotgun mic. Mostly used for live event production. I have a Tascam DR-40 as well and use it sometimes for live events however I liked being able to adjust my knobs with the beachtek. Thanks
What is your goal in purchasing it? Old thing not having enough gain, or something else?
You can check it, as you have it.
