Thank you all for your input on my late test footage. With your help I was able to make some notable adjustments and get much better footage on my actual shoot date this past Sunday in comparison to my test shoot. I will continue to post some screen shots and footage as the editing process progresses as long as there is interest in the topic.
-Ivan
@thepalalias - I did not get a chance to flash CM Night yet but I think I will tonight. Again - this Sunday I'll have a second go around at the shoot and if CM Night is that noticeably better: I'll be using it. Thanks for the suggestion and pointing out the aforementioned subtle difference reference. I'd really like it to be THAT much better.
@IvanUskokovic I would actually really use CM Night for that kind of a shot. The difference is not as subtle are suggesting. CM Night gives much cleaner shadows and detail in that kind of a shot. Sedna still looks good (and great to shoot with) but CM Night is noticeably better.
@Sangye & @rockroadpix - I'll attempt to lift the lower mids.
@Roberto - I understand.
Not a fan of that "look"
Of course not. It was "just for analysis," as I said, to get a black somewhere. I thought you'd understand. There is plenty I could have done and that you can do to alter the footage in post.
I agree, it's not unusable.
@rockroadpix - I agree. I wish the same. I was really short handed when it came down to lighting. Last minute I pulled together two lightbulbs and threw them on stands - but it just wasn't enough. I'm now wondering if I'll be able to get away with the footage I have, lacking that stronger light on the talent's face/eyes.
I like the tonality and the textures.
My 2 cents is that I would have had an eye light for the talent. Just something to help bring out the expression a bit.
@Roberto - Not a fan of that "look", at all. Thanks though.
It may be just your jpeg, but it seems at first look that with a room that dark there's got to be a black somewhere. The letterbox black bars make for an easy comparison.
So I've done the obvious - just for analysis. (see pic). Even under-exposed as it is, there's still some nice light on the talent it you wanted a darker, impressionistic look with emphasis on the lit portion at the rear of the bar.
As @x_worpig_x says, "Setting up a few lights wouldn't hurt".
Attached is a still from the footage taken Sunday. Critics and commenters are welcome as I continue on with my editing process.
@IvanUskokovic yes post the footage!
Thank you all for your help. I shot yesterday in Sedna AQ1 C and was able to keep the iso at 320, shutter speed at 1/50th, wide open at f/0.95 (which is surprisingly sharp on the new Voigtlander 17.5mm!) - by simply using a lightbulb as fill. Nostalgic -2, 0, 0, -2 seemed to help too. I will be posting transcoded footage shortly if anybody is interested.
@rajamalik - Thanks. I think I'll stick with C on that note.
Anybody think Sedna A or B would be better than C in low light?
@x_worpig_x & @jpb1138 - I'm working on trying to get more light today. Perhaps just a great number of candles that burn brighter than the ONE candle that lit the entire scene present in my video.
@fohdeesha - You make a fantastic point. I am going to shoot a quick test in the next couple hours with a little more light and -2 contrast.
I agree, about light. not even some lights. How about just ONE light and the entire video would look better. Either fill in some shadows or emphasize the highlights more.
The Hack really wont make a big difference. If you are using Sedna I would stick with that. Canis adds some color to darker setups but its nothing like WOW this takes my bad footage and makes it good. It's more subtle of a change.
Setting up a few lights wouldn't hurt.
@Meierhans - Thanks for the direction! I'll take a good look at the Driftwood Canis Majoris 'Night' patch today.
Driftwood VY Canis Majoris 'Night' was especially designed for low light. I would give it a test before going on set, Driftwood wrote that it might hang. Then again one hang out of 20 times you hit record might be ok if the quality is really better. http://personal-view.com/talks/discussion/3056/driftwood-vy-canis-majoris-night-day-pm-skin-tone-soft...-more-to-come/p1
I would take at least some LED panels and some kino flo´s with me (+CTO gels to match with light in there). If you really want to stay "all natural" get some candles with big wick so they burn larger.
