I found a set of 14, 20, 30, 50mm lenses is good. See http://personal-view.com/talks/discussion/comment/63058#Comment_63058
I have 14mm 2.5, 20mm 1.7, and Ai-s 50mm 1.4. Definitely not interested in Sigma 30mm 2.8.
@shian used 0.7x converter on his Ai-s 50mm 1.4 http://www.personal-view.com/talks/discussion/comment/61642#Comment_61642 Smart idea. Less # of lenses. Easier color grading.
I'm looking for 0.6x converter to turn Ai-s 50mm 1.4 into 30mm 1.7 if one third stop light loss.
Calvision has 3 different flavors for 0.6x converter. No idea which one will work if it works. http://www.cavision.com/optics/industrial/adapters.htm
Any advice is greatly appreciated.
@stonebat thats why I was looking at the big adapters with 77mm/82mm filter threat and a glas element that is not smaller than the huge front lens of the Olympus. The only thing I read on the internet is, that many wide angle adapters have a (light) brighness fall off from center to corner.
Another use of 0.6x converter.
x14-42, Leica DG 25mm 1.4, and Nokton 58mm 1.4 SL II N give very similar color tone/contrast. Apply 0.6x on the 58mm. There goes a set of 14-42/25/35/58 focal lengths.
Both Ai-s 50.4 and Nokton 58.4 have F-mount. Darn... I gotta find the magical 0.6x converter!!! Maybe Diablo III must have such magical item!!!!
Has anybody used one of the high grade wide angle adaptors on a good lens?
e.g.
http://www.vfgadgets.com/camera-gadgets/red-eye-wide-angle-adapter
http://16x9inc.com/shop/cart.php?m=product_detail&p=661
I have the Olympus 14-35mm F2.0 but need something a bit wider, so I have the options of...
1) Tokina 11-16mm F2.8 ( - only 11mm/ + a real lens)
2) 0.65x 77mm wide angle adapter ( + 14x0.65=9mm/ - optical quality???)
The adapters are a (small) bit cheaper than the Tokina, but image quality is more important. Sample pics/vids would be awesome. (I had a look on the web, but didn't find any real test with large sensor cameras.)
Has anyone tried this 0.6x converter on nifty fifty?
@shian I'm adamant about 70% focal length increment from a waist up portrait lens to a head portrait lens. e.g. 30mm * 1.7 = 51mm which is close to 50mm. 50mm * 0.6 = 30mm. So I'm looking for 0.6x converter. Yes I would like to see compression (or decompression???) on the Nikkor nifty fifty. It's one of few old designed vintage lenses that are still being manufactured.
@Roberto I'm not a fan of ETC, but that's an interesting idea.
@Ralph_B I see. Currently I'm happy with 14mm 2.5 and 20mm 1.7. There's DMW-GWC1 available.
@stonebat I've tried several different wide angle adapters on the 20mm lens, and all produce very bad blurring at the edge. What I've learned is that WA adapters are lens specific. They are optimized for one lens, and eveything else is going to be degraded to some degree. I know this doesn't help much. Hopefully there's an adapter out there that works well with the 20mm. I just haven't found it.
I've tried something similar with my 14mm pancake, this time using .6 and 1.5 extenders:
ETC OFF
14mm = 28mm equiv*
28* x .6 = 16.8 equiv
28* x 1.5 = 42 (vignette + barrel distortion)
ETC ON
28* x2 = 52 equiv
28* x .6 x2 = 33.6
28* x 1.5 x2= 84
Makes a very compact kit with 6 focal lengths!
There is some mild vignetting on my adapter, you'll see it on the scopes in one of the next sets of FS Tutorials. it's about a 1/4 stop difference between center to edge. It's not obviously visible, but when analyzing on the scopes you can see it....very gradual though.
I don't notice any distortion, but I think there's probably some there. So it is not ideal. But it saves me having to lug more lenses around, and it provides more framing options off the same glass. obviously it doesn't change the lens compression, but I love the compression on my 50.
