I have to shoot my high school's graduation video, but the thing is I have to broadcast it live on Skype for a Iraq Soldier so he can see his sons graduation and wanna shoot it with my GH2. How would I go about doing this with my GH2?
Yup
As people noticed here - you'll have much better version that you can put on private youtube or send on disk.
@Vitaliy_Kiselev Alright thanks for the info
I think that you want to make something very hard to do and manage.
Really, use simple phones or USB cameras.
@joeDirt03 Is there anyway I can use multiple cameras hooked up to this teradek cube? Or maybe shoot with a Iphone and GH2 and connect them both back to my pc and use wirecast to broadcast it to like skype?
@jakef Thanks
No worries, glad there was usefull ideas. I was looking onto this when i was trying to strap my GH2 to my trex500 heli to see what what the is camera seeing. I still havent flown my heli; it's a very consuming hobbie to master and i dont have that much time. Much prefer using free time with the Gh2.
I agree the easiest for you would be to strap an Iphone or similar video skype device together with the GH2 to your camera rig. WiFi signal may be more reliable.? This way you have a secure live skype feed as well as gh2 quality footage to keep. :)
Thanks you everybody for all the help!!
@DirkVoorhoeve Uh yeah I could probably shoot it with an IPhone
@ssh Yeah I wanna shoot it with my GH2 but I could use a IPhone the quality wouldnt make a difference
@jakef Thanks that helps a lot
Some months ago a friend of mine and I did some experiments of what camera would give the best visual results with Skype.
Among those we could try, the winner was the Sanyo Xacti HD2000 - it's one of the few cameras which have a relatively good (fixed 10x zoom) lens, can capture 1080p60, and it has a dedicated "web camera" mode where it transmits live data via USB 2.0. (Alas, the Xacti HD 2000 is not sold anymore - and I don't know how good the Panasonic successors to the Xacti line are regarding their "Web camera" profile.)
@DirkVoorhoeve Have you ever used Skype? How big of a difference do you think you will see between iPhone and GH2 footage in Skype over a sat link? Don't overengineer stuff, pay attention to the objective and find the least complicated and the most reliable solution. T34 vs Tiger kinda thing.
HDMI out of GH2 into a black magic intensity card, and software than can see that card. We use wirecast, allows multiple sources and live mixing and basic CGI titling etc.
Keep in mind most web broadcasts are not in HD, most are SD due to bandwidth concerns on your end and the viewers end , unless you have some sort of a trans coding going on for low bandwidth viewers.
So really a good quality webcam would work.. but it is all "automagic" , your not going to get much for manual controls, we use a cheap c310 Logitech for a 4th camera that's a behind the scenes "studio cam", its HD resolution but its colors etc are nasty compared to a decent camera like a gh2 or even our older ENG cameras. but it doesnt really matter for that camera.. its not important video , just used during breaks to fill time with something other than a graphic or pre-recorded roll.
A good used SD cam would be better than a web camera , use fire wire to connect to the PC. We use a early HDV Sony as our 3rd camera via firewire , works well.
@ssh you mean to shoot with iphone instead of GH2? Guy wants to shoot with his GH2.
My WHDI is currently installed about 15 meters apart and is crystal clear even though there are two walls inbetween, but i agree 5 meters if you are moving around i'd say maybe even 10-25 meters if you stay reasonably still with no obstructions.
The only question is; how do you get that hdmi signal to skype? My primitive mind think you should plug it into a hdmi screen ie, lilliput or similar and position it so that the computer webcam can see the image...
Problem solved...? ;b
what HDMI capture card are you using btw?
eyefi only sends the video AFTER you stop recording, not while recording. It needs the file to be complete before it sends it over wifi.
WHDI is great to get it to your computer. put your receiver within 5 meter range of your camera though, to be sure. Then you can walk around freely without loosing the video signal (i've tested it myself). See this topic for a few devices.
have a look at this article I just posted here. http://personal-view.com/talks/discussion/3238/wireless-hdmi-and-smallhd-dp6-interesting-article#Item_1
It may be relevent to your needs if you are able to get/convert the HDMI into your computer
Using a RX TX 5.8Ghz with a HDMI converter box (with 5v battery supply for each) will give you wireless analogue outputs, however i'm not sure how turn the analogue outputs into a webcam for Skype.
Receiver/Transmitter (less quality but longer distance) http://www.ebay.co.uk/itm/5-8Ghz-FPV-Video-A-V-TX-RX-200mW-2-0Km-RC-Plane-Car-/250794313653?pt=UK_ToysGames_RadioControlled_JN&hash=item3a648187b5
Hdmi Converter (I've got this one and it works) http://www.ebay.co.uk/itm/1080P-HDMI-Composite-3-RCA-AV-CVBS-S-video-Converter-DVD-CRT-TV-PS3-Apple-TV-/320886614482?pt=UK_Sound_Vision_Other&hash=item4ab65529d2
Or the WHDI Sender that inputs HDMI and Outputs an Hdmi digital signal in the other side via 5.8Ghz (I have one of these for my tv at home but untested as i'm not sure if HDMI protection might interfere with the signal)
Hope this helps.. :)
