@Piotrj No, I have not encountered that. Have you been able to reproduce the same behavior in two different applications?
Here's another try with Orion 4vB:
Set to Smooth with everything on -2 and retro color graded. Thoughts?
@andyvia68 Which setting did you use?
Glad Nick handled it for you. :)
@mclaren Thanks, but I was actually asking - are there any MTS clips at all that you can (currently, not in the past) add to the session without getting the error? I`m trying to make sure that it is in fact specific to the individual clips as opposed to any other sort of configuration issue.
Getting this message in Final Cut for a Mysteron Clip importing The following clip encountered an error during import and is still referencing media on the camera:
Import Failed Clip Name: 2012-05-03 20:26:58 Event: Kyle Wedding
Original Name: Clip #3 Volume: PRIVATE Stream Error at: 00:00:24:04
Just donated again. I encourage anyone who can to give these guys some coin. I would say what they have given me is the difference of a really expensive lens. $20 here or there is change for that! Come on all. These guys have brought so much value to the table. Sick cam, sick glass, now a sick hack!!! I feel like I am on the bleeding edge :0)
Can't remember but he needs to check. Mysteron was for sure and all Canis are limited to 4mins for safe writes. Anyone wanting to test spanning out on Canis would be good. Thanks for all your input Per. I'm still bloody busy at the moment and can't answer too many queries till next week. That won't stop me putting up the rest of the settings this week/end. Four more to come. :-)
People will have to wait and hopefully donate to Vitaliy. I think people are under the impression he gets a lot of donations - and thats not true. Most people just sign up, take the settings and leave. Disappointing.
@driftwood Did you add the the time limit into the Sedna settings more recently? I remember the option did not exist when they settings were released.
@mclarenf1 Uncheck the time limit (which is set to 4 minutes) in ptools found under patches for testers - and then check > 30 min limit too found under pathes for users.
@mclarenf1 If you have the SanDisk 64GB 95MB/s, then Sedna should already be spanning in 24H. What exactly is happening at the moment?
@mclarenf1 Just to control the variables, what results are you currently getting with other filetypes? I just want to rule out that codec or FC X have gotten corrupted somehow.
