PTool 3.61d topic
  • 352 Replies sorted by
  • @Vitally_Kiselev
    Yea, reducing quality... but improving the "look" for us picky cinema junkies. ;)
    I'll keep it to the other forum, as not to confuse people...
  • Just a quickie before I patch - does the FM upgrade reset your settings?
  • Guys, can anyone tell me precise value after that we got bitrate dropping to very low, like 6x bitrate?
    How about binary search?
  • Successfully patched my Japanese GH2 using PTool 3.61d through Wine on Mac, how nice to finally have English menus! Will post footage with the recommended settings tomorrow. Outstanding work Vitaliy!
  • @bwhitz
    GOP related part of your post deleted.
    Consider this topic "GOP free". Use proper ones.
    for Wine google at "Wine NET Framework installation".
  • @kae
    Please try to keep GOP changed settings to corresponding topic. :-)
    As all you are actually doing is reducing quality :-)
  • @kae
    Does anyone know of any other stream-analyzers though? Streamparser will not work with Winebottler because of a bug with NET Framework 4 or something...
  • @blues
    You don't need any "standard patch" here.
    Just go to bitrate settings, look to hints and input this value. It is simple as that.
  • For testers only.
    3 GOP 24P Footage Tests successful with new Ptools is posted here: http://www.personal-view.com/talks/discussion/335/ptool-3.61d-gh2-avchd-encoder-settings/p4
    I'm getting about a 46mbit average video rate with a stable 3GOP.
  • can anyone give us a standard patch for gh2 hack? or can we use any patch we used in GH13?
  • FWIW - Hacked SH footage using suggested settings would not play well on Panasonic Viera HDTV. Occasional video slowdown and stuttering audio. Same footage plays fine on MacBook Pro where video and audio quality was excellent.
  • On Transcend Class 10 32GB cards I get:
    FH 35Mbits No Crashes.
    FSH 42Mbits Recommended Settings Crash if heavy scene detail and or Motion. Cannot Write To card.
    24H No problems at 42Mbits it wont crash yet. Seems to be solid. However get some weird artifacts. "Some objects on the scene seem to be dancing in place independent of where they should be statically located."
    I will however reduce to 3x Mbits on all modes until I can get a faster card that wont hang.
    Only way to wake up from crash is to take battery out.
    Thank you Vitaliy, I donated months ago but will again. :D
  • Mr. V. just to clarify . . . 3.61d has "end user" friendly, stable settings, correct? (Along with, of course, properly labeled and easily avoided "tester" settings.) Also, is there a topic dedicated to the finer points of running PTools on Macintosh? I looked around but didn't see one.
  • @Ptchaw
    Patches for End Users > AVCHD Movie Mode > AVCHD Compression > Video Bitrate 24H
    When you click it, a little window pops up and gives suggested values. Edit your settings accordingly.
  • (never mind, solved)
    Also, just to confirm for anyone running Linux/debian variants, PTool works nicely with Wine out of the box.
  • AVHCD Compression
    I tried
    FSH: 36 Mbit
    FH: 24 Mbit
    and
    24H: 36 Mbit
    24L:24 Mbit
    for me only these values are enough stable for my SD cards
    works great on:
    SanDisk class10 Extreme 30mb/s 16GB
    and
    Transcend class 6 32 GB ...
    No crashes, tried 40Mbit there was crashes on intense scenes ...
    (faster SD cards might work ...)
    Not much saturation at 36 Mbit, much better than 17 Mbit at 1080/50i ...
    Thank you VK
    File: F:\PRIVATE\AVCHD\BDMV\STREAM\00000.MTS
    Size = 366 938 112 Bytes (1 911 136 Packets)
    Stream: Max Speed = 38 614 520 bps
    Mode = 1080/50i
    PCR Timing Interval = 0,095 seconds
    Clip Time = 0:01:17,32
    Average Total Bitrate = 37 965 660
    Average Video Bitrate = 36 805 478
    Average Audio Bitrate = 235 072
    Average Other Bitrate = 925 109
    Max GOP Size = 2 686 080 Bytes (21 488 640 bits)
    Video Frame Size (Min/Ave/Max)= 37 248 / 187 875 / 408 960
  • Raw footage shot with the GH2 and Ptools 3.61d using Vitaliy's recommended settings for 1080 24p. End user settings only.
    Footage was shot against a plasma plate to provide a lot of action in the footage to ensure the bitrate was high. Bitrate shits out for the first few frames. Not a big deal.
    SD Card is a 16GB Transcend Class 10
    Vimeo
    Login to download RAW footage.
    Youtube
    File: E:\temp\Hacked Panasonic GH2 1080 24p PTools 3.61d 42mbps Recommended Base Settings.MTS
    Size = 174,526,464 Bytes (908,992 Packets)
    Stream: Max Speed = 45,275,110 bps
    Mode = 1080/24pN
    PCR Timing Interval = 0.095 seconds
    Clip Time = 0:00:31.57
    Average Total Bitrate = 44,222,143
    Average Video Bitrate = 42,703,063
    Average Audio Bitrate = 470,168
    Average Other Bitrate = 1,048,911
    Max GOP Size = 3,092,928 Bytes (24,743,424 bits)
    Video Frame Size (Min/Ave/Max)= 25,728 / 227,184 / 772,416
    1406 x 827 - 124K
  • Stupid mistake. Missing a "0" at the end of FSH/SH bitrate. You'd think I'd know better by now. I looked at it a hundred times then finally figured out.
  • @plasmasmp
    Try to adjust value a little, lower or higher.
    I tested 720p and all had been fine.
  • (edit) not an issue
  • @plasmasmp: 720p50 look also on encoder settings topic ...42MBit-rate with B-frames
  • Using just the "suggested values," 720p SH records at a 4-5mb. The attached file shows 720p SH mode with just the suggested changes
    (notice: if you are looking at this thread and have this issue make sure that you have the correct number of zeros on the end of your FSH/SH bitrate)
    1295 x 677 - 258K
  • About 1st sec hic-ups. It's always a good practice to run about 5 seconds of pre-roll anyways (maybe more maybe less). Anyone who works with video typically does that already , so unless Bigfoot suddenly pops out and charges you from the woods....it doesn't really matter.
  • Very true. I remember this was one of the keys to getting high bitrates to work with the GH13. This may actually be somewhat of a blessing.
    Chris
  • @cbrandin
    We'll fix it with time. And remember, you have many other things to try now :-)
    Btw, it is always good to have low starting bitrate for stability.
