@Vitaliy, I have measured the two ND tiffens I have are 3.8mm. Also measured 6 others (All Tiffen) .. also 3.8mm
Has anybody any experience of the lanparte mattebox with 4mm thick filters.
I want a mattebox that will safely and easily hold 4mm filters, and enable me to use both filter slots if filters are 4mm thick.
You need to get actual filters and measure them yourself.
Glass Cinematics filters work pretty fine with all this MBs.
Hmmm .. sounds like a bit of an oversight .. my guess is they used cheap acrylic filters when designing it. I think I'll look around a bit more.
With 4mm filters, can you use two at once?
The 4 mm filter will fit in, but it will not lock as it should. So you can work with it but need to be very careful on filter change.
Black ProMist 1/2 is one I wish to get .. http://www.bhphotovideo.com/c/product/55655-REG/Tiffen_44BPM12_4x4_Black_Pro_Mist_F_X.html .. if you go to the specifications .. it's 4mm thick.
Similarly the Formatt is listed as 4mm at bhp http://www.bhphotovideo.com/c/product/606477-REG/Formatt_BF_4_ND_6HD4_4x4_HD_Neutral_Density.html
Same with the polariser http://www.bhphotovideo.com/c/product/606485-REG/Formatt_BF_4_CP2000RH4_4_x_4_Hi.html
Click the specs tab
I just don't want to spend $400ish and find I can't use the filters I wish to use.
Any further thoughts?
Can you use both holders at the same time? Or does a 4mm filter prevent the second tray being used?
Can you confirm if when fitted the 4mm filters protrude beyond thickness of holder?
What filters are you looking at? I have the 4x4 version and I've had no problem using a Tiffen 1/2 Pro-Mist or Formatt ND 0.6 and Polariser.
