For some reason, this topic can not be found by forum search. I suggest It becoming a sticky, always newest version! VK? please? :)
It's simple. Just "follow" this topic.
I thought VK created a new topic for each version?
Guys, http://www.personal-view.com/talks/categories/hack-development category is less then one page long. Spend few extra seconds, it is not very hard.
@thepalalias: right. that was my problem. @VK: Thanks, did not use Categories before.
Thank you VK! Super! One of my favorites, will be one of the most used:
I recently started to use the 720p and 1080i modes and was shocked that the camera switches to auto iso as soon as I hit the red record button. (visible exposure shift when panning from window to dark room)
Everything is set to Manual Mode and works as expected when using the 24p or HBR modes.
Its probably not the iso shifting its the I-dynamic make sure that is set to off. The Auto Iso thing is a false reading the hack causes.
@anti12 Do you get the same result when you hit the shutter button instead of the red record button?
@thepalalias No the iso stays also fixed in "Manual Movie Mode". So I guess it's a feature to have auto iso on when using the red record button while not in Movie Mode.
@all Thanks a lot!
Hi @Vitaliy_Kiselev, should we expect anything new with the upcoming Ptool v3.66 for "old" bodies (GF1, GH1, GH2) ? Txs !
If I'll have time I could add tables to GH1. But most probably, not, only in next release.
