I recently bought this cable http://www.alzovideo.com/alzo-dslr-rig-accessory-hdmi-audio-cord-set.htm for my GH2. They come in two varieties. The red cable will make the cable direction go down and the white cable(which I got) sends the cable up . It's not super flexible, but probably twice as flexible as the regular short HDMI cables that I previously bought on Ebay.
Here is an interesting Micro HDMI cable http://www.droneland.nl/en/droneland-fpv-30cm-soft-hdmi-cable-micro-interface.html
Not angled but thin
I wanted to ask, if your camera GH2 work PAL or NTSC system? because when I turned on my camera GH2 PAL system I do not view the HDMI converter. I can not find the problem.
This jack orient down.
Still need an answer.
Please, guys, lets move this to another place. I did the mistake to start the topic in the wrong place. Apology for the inconvenient to all.
Does the angle of it impede with the mic/remote jack? In other words does it orient downward or upward?
TIA
Also have this cable - does what it says on the tin
Guys, keep this out of this topic. use proper one.
I got same converter for $39.88 with free shipping from Ebay http://www.ebay.com/itm/HDMI-Composite-S-Video-Converter-HDCP-analog-AV-RCA-/270923273574?pt=LH_DefaultDomain_0&hash=item3f14491566
Thanks, been looking for ages
Just to confirm that the HDMI to composite converter, from the company C & E, model HD-Video Converter-T24A works as expected with GH2 mini HDMI output. It comes with S-Video and three RCA outputs (audio and video). It has Automatic dictation of Pal & NTSC signal. It works in playback and recording mode. I'm using with a VeriZoom TFT 7" monitor.
I got it from Amazon. $51.00
