*** THIS IS A CONTINUATION THREAD FROM SERIES ONE & TWO CAN BE FOUND HERE:-
ALL PRESENT DRIFTWOOD SETTINGS LINKS ARE NOW INCLUDED BELOW ALONGSIDE THE SETTINGS - SEE LINKS.
ALL Settings require Panasonic firmware v1.11 & ptools 3.64d '200212' required). Settings for GH2 & GF2 Lumix cameras.
THE LATEST SETTINGS
VY Canis Majoris- Release TBC
Driftwood Sedna 'Settings' for ptools 3.64d- Release 15th March 2012, 01:30am
Stats: 24p Intra, 1080i/HBR Intra, 720 GOP3/GOP6 all settings as Orion with Sedna Matrices:-
A = High Detail matrix Good for Wide full detail shots.
B = Good allround detail matrix Great all round wide / mid shots.
C = Softer detail matrix Softer skin tonal detail.
Two packs, one at Quantisation 20 (default), the other AQ1 (pushed the Quantisation and bitrate further still). Note: AQ2 to 4 is unnecessary. Q20 is REALLY pushing the Quantisation to best levels without having to use AQ. Q20 Bitrate is measured to detail and will achieve in places AQ3 or AQ4 size bitrates without distorting Q so much as before.
Setting Links;-
Driftwood 'Cluster' v1 With Orion (AVC Intra adapted) Matrix VBR 'Settings' for ptools 3.64d- Released 9th March 2012 1am
Stats: Upto 72M 24p, Upto 36M HBR, Upto 36M 720p modes. (*All REC MODES include B frames)
Cluster v1 Link: Cluster v1
Driftwood Quantum X (v4d Orion) 'Dark Matter' Matrix Pack + HBR FIX - CBR 'Settings' for ptools 3.64d- Released 18:30pm 06/03/2012
Details: Featuring the new 'Dark Matter' matrix set (three version variations) based on current Orion Matrix with hi/lo freq adjustments. Plus 720p on 9/6 GOP. AQ is NOT required. This is a constant Q (Q8) CBR setting which performs measurably better than with AQ4 on. All other settings as before. INFO: Orion 4d with Dark Matter matrix pack. Three adjusted matrices to try out, all scaled from perceived HVS Great Quality (v1) to middle of these (v2) and perceived HVS Highest quality (v3). HVS = Human Visual System. This is sharper than the Orion matrix of yore which is still great but many of you wanted to pull out a few extra stops. Let's see if this helps YOU. Only other changes from Orion 4b are GOP Releated, 720p is 9/6 for NTSC/PAL.
Orion 4D with 'Dark Matter' Matrix Link: Orion 4D
Driftwood Quantum X v5b and v5c 'β Pictoris' (baby Quantum X) VBR & CBR versions 'Settings' for ptools 3.64d - Released 10:30am, 01/03/2012
INFO: Two versions - 1) CBR constant Bitrate at 75M, 2) VBR Adaptive Bitrate 35-75M
There are actually four versions (two in each pack CBR/VBR versions) for you to try out of Pictoris, two different matrices - v5b is the new hybrid matrix, v5c is the Orion included matrix. with NEW Driftwood scaled Panasonic GH2 Matrix meets AVC-INTRA Matrix hybrid (somewhere in the middle of Orion matrix meets GH2 Stock matrix) inc;- Settings primed for 50/75M Standard Rec Modes plus additional 25M for Etc Mode, 1080p24 on INTRA 50/75M Standard/75M Etc Mode, 1080i50/60 INTRA 50M /75M Etc Mode, 720p50/60 GOP6/9 40/75M, Standard/75M Etc, MJPEG Highest Quality 1920&720 Mjpeg modes. Good standard SD card recommended
Two Zip files below contain the settings: Download all packs and try them out:
Driftwood Quantum X (v4b Orion) CBR 'Settings' for ptools 3.64d- Released 00:15am 28/02/2012
INFO: Settings include;- Quantum v9b style constant bitrate patch with full AVC-INTRA Matrix ; Requires firmware v1.1 and ptools 3.64d '200212 dated' (*Not compatible with 180212 dated ptools); CBR style 154M INTRA 108024p; CBR style HBR & 1080i INTRA 100M+ Max; CBR Style GOP12(PAL)/GOP15(NTSC) 720p 50/60 - 80+ Max; AVC Intra Matrix all round; GOP related Adjustments for B frames; EX Tele and 80% mode support. SD_Card=V good Class 10; SanDisk Extreme HD Video recommended
Orion v4b Link: Orion 4b with AVC Intra Matrix
Driftwood Quantum X (v3b Rocket) RC VBR 'Settings' for ptools 3.64d - RC Released 00:15am 28/02/2012
INFO: Settings include;- Adaptive Hi Bitrate INTRA on 1080p24 upto 154M; Adaptive Hi Bitrate 25p(50i PsF) upto 100M; Adaptive Hi Bitrate 30p (60i PsF) upto 100M+; Adaptive Hi Bitrate INTRA 1080i modes upto 100M+; Hi bitrate 720p modes on GOP 12/15 with B frames upto 50M safest; Highest Quality tested MJPEG on 1920x1080 (720 compression mode); Highest Quality tested MJPEG on 1280x720 (480 compression mode); EX Tele Mode support (will increase bitrate usage by around 20M); 80% on 1080p modes (will increase bitrate usage by around 25M)
Rocket v3b Link: Rocket v3b
Driftwood Quantum X 'SpanMyBitchUp' v2b - Released 10:15am 25/02/2012
Link: SpanMyBitchUp (SMBU) v2b
INFO: Updated version of SpanMyBitchUp.
Settings include;- Adaptive Hi Bitrate INTRA on 1080p24 - upto 100M. (* Only for GH2); Adaptive Hi Bitrate 25p(50i PsF) INTRA - upto 100M; Adaptive Hi Bitrate 30p (60i PsF) INTRA - upto 100M; Adaptive Hi Bitrate INTRA 1080i modes - upto 100M; 720p modes on GOP 6 with B frames - upto 98M; Highest Quality tested MJPEG on 1920x1080 (720 compression mode); Highest Quality tested MJPEG on 1280x720 (480 compression mode); EX Tele Mode support; 80% on 1080p modes; 24L, 720/1080i FH/H settings on Trick mode (encoder calcs bitrate)
Driftwood Quantum X (v2 Rocket) 'Settings' for ptools 3.64d - Released 22/02/2012
INFO: Adaptive bitrate settings. (See attached settings zip file below). Settings include;- Adaptive Hi Bitrate INTRA on 1080p24 - upto 154M. (* Only for GH2); Adaptive Hi Bitrate 25p(50i PsF) INTRA - upto 100M+; Adaptive Hi Bitrate 30p (60i PsF) INTRA - upto 120+; Adaptive Hi Bitrate INTRA 1080i modes - upto 120+; 720p modes on GOP 6 with B frames - upto 98M; Highest Quality tested MJPEG on 1920x1080 (720 compression mode); Highest Quality tested MJPEG on 1280x720 (480 compression mode); EX Tele Mode support; 80% on 1080p modes; AVC INTRA Matrix on I Frame coding with Flat 16 Matrix on P/B frames
Link: v2 Rocket
These settings are dedicated to VK @Vitaliy_Kiselev (master in control) and Chris Brandin @cbrandin (thee font of information).
IF YOU LIKE THESE SETTINGS PLEASE PAYPAL DONATE (ABOVE) TO VITALIY FOR HIS TIRELESS WORK ON GIVING US THE HACK.
Ok you spotted the difference/ However, the Mysteron clip was shot at 800 ISO f5.6 shutter 100 - The RAW at 400 ISO f4 1/40 shutter.
This thread is about to close... new thread going up as we have over 1000 comments again...
The new thread link 4 is at:-
PLEASE DO NOT POST ANY MORE COMMENTS HERE. VK IS ABOUT TO CLOSE THIS THREAD.
@Mark_the_Harp Good tip! I have also noticed the same thing with my high iso inside shots. They seem to clean up better than some of my low iso outdoor shots!
Noise isn't always bad anyway - by which I mean, if you have a subject where you get a lot of banding (smooth gradation of light falling on a whitish surface, for example) then a noisier setting which you then noise-reduce in post will pretty much eliminate the banding, whereas if you have a very clean shot you will be stuck with banding.
I was experimenting with a Nikon 1.4 at a lower ISO (giving very clean video) and the banding on the tall candle was horrendous as the candle in the cage (on the left side) flickered. I went back and shot it at a much higher ISO and denoised in post, and the attached resulting image has almost no banding. You can still see some, but believe me, the low-ISO version was really, really bad whereas this noise-reduced version is pretty much fine.
So noise can be your friend!
@shian @Meierhans @itimjim A way to make sure you are coming from higher ISOs down to the ones you want: for example set your C1 to 1250 and then bring it down to 640 for shooting. Even if it "goes to sleep" it will wake up again with 1250. So you are always forced to work around the bug.
@ishvar "There is however quite a lot of mosquito grain in Driftwoods patches fuzzing around @ higher iso's "
I guess you refer to normal sensor noise, not mosquito noise? While sensor noise is unavoidable and will get more visible the higher you set the bitrate - cause noise is details and low bitrates somewhat "denoise" by simply trowing this detail away - mosquito noise is the result of heavy compression. This is a big difference, sensor noise can be cleaned very well with Neat Video or MB Denoiser, while mosquito noise is a bitch in this respect.
In short: If a setting gives you alot visible sensor noise thats a feature, if you see mosquito noise, its a bug.
(And yes, I know there is things going on with matrixes and deartefacting that do play a big role in how noise shows up in the compressed stream - but we are quite far away from visible mosquito noise IMHO.)
@thepalalias Yeah, pretty much what I was trying to say. The thing about a higher bitrate though is it definitely effects playback, it doesn't really effect the rendering of an edit for example.
Good point @shian about the sleep mode. I think I've been caught out by that quite a few times. 2nd row ISOs for me from now on.
@ishvar Panasonic is not involved, it was an April Fools joke. Although I do a lot of testing with the GOP1 settings, for any work/project that I do I always use a GOP3 setting. Personally, although I do have a pretty fast PC, I've never experienced any additional hassle or overhead working with GOP1 footage over longer GOP footage. Rendering and grading should actually be a faster process as the applications can build frames quicker (the reality is no real noticeable difference on the whole), grading is also a lot more flexible with these lower GOP settings.
After hacking my black model GH2 about 50 times i have come to the following conclusions: Nick Driftwoods patches have absolutely stunning IQ and are the best around. I love Sedna and am completely blown away by the Mysteron burst quality, though very experimental. I cannot test it properly for i have only shitty Trancend SD-cards @ this moment. There is however quite a lot of mosquito grain in Driftwoods patches fuzzing around @ higher iso's and your high mbs footage will keep your pc/mac bussy and hot! Rendering and grading is more difficult than stock settings of course. Footage will also not play stutterfree in all mediaplayers because of Intra/GOP1. (but all this most of us will know) Grainwise f.i. Cake v2 by balazer, Sanity by Ralph B and towi's Pal settings are is the best around, especially for HBR 25p mode! Gop 3/6/12 plays better in most players and is easier handled in post. I will test Cluster V2 against towi's pal50/pal66 settings the day it will be released..... I am also very curious what will happen to P.V., now Panasonic is directly involved. GOP1/Intra on the GH4? lol @driftwood if i can run some test for you pls let me know! My YT clips: http://www.youtube.com/playlist?list=UUsIRMqYKoU_Wz7UE_bqpt8g&feature=plcp
ISO Bug after sleep mode is VERY bad news, I did not recognize that before. For larger projects we run a external V-Mount anyways and disable sleep mode completly, but for the small stuff, jumping around without the heavy rig this is a real drawback. It means you either have to do 5 clicks each time the cam wakes up (yes, dangerous to forget) or disable sleep mode and empty your batteries in a quarter of the time.
This should be top priority to fix for Panasonic! I don´t understand at all why they did not adress this in the firmware update.
However, back on topic: Sedna is really amazing, I did not try Mysteron until now, but Sedna is already soo freaking good, even for the big screen. Thanks alot!
yeah - try shooting with it in a real production situation when you are running around with your head cut off like I am usually, and when you forget you're in 640, and the camera goes to sleep, and then wakes up into a mess of noise and ruins your shot. You'll tell 640 to fuck right the hell off. Cuz it happened to me, and I won't even mess with it anymore.
@Kihlian Haven't read that thread yet. Will check it out soon but am busy with the music video stuff right now. :)
(The one that mixes Sedna AQ1 C with HV30 footage and heavy grading.)
What about the ´magic´ 640 ISO, that in the @yeehaanow test shows less noise than 160?
@GH2_fan Best of luck with you finding one that works. I wish I could more help. :)
@thepalalias & @mee That is very interesting, but I dont understand how there could be more than one Sandisk 16GB or 32GB Class 10 45MB/s???
I have checked the link and the closest I could find was something like this?: http://www.ebay.co.uk/itm/280857551257?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
@GH2_fan just to give case and point. I had a 45mb/s sandisk 16gb card that had error after error even with some of the more gentle patches. I exchanged it for a 95mb/s card which just arrived yesterday (after about 3 1/2 months waiting). The 95mb/s card is working without flaw so far including my test last night of moonlit cherry blossoms at 6400ISO using mysteron on 1080p.
@Shian Thanks for mentioning "sleep mode" - I neglected that.
@Rigs Got it. :) Was the noise similar for the 2nd row ISOs? I normally do not have issues in the blacks if it is properly exposed, except for the occasional "flickering shadows" issue. Do you have a picture so I can see if it is that one or a different issue?
@GH2_fan The problem with the 45MB/s SanDisk cards is that there are several versions. Some of the versions are discussed here.
http://www.personal-view.com/talks/discussion/90/sandisk-extreme-sdhc-cards#Item_301
Some of the SanDisk 45MB/s perform well, other models less so. If you get the 95MB/s SanDisk, there is currently only one version and it is the best-performing card that has been tested so far. So if you want peace of mind, get the SanDisk 95MB/s but if you find a great deal on the 45MB/s version, make sure it is the right one (check in that link I included).
@thepalalias Thanks for replying back, that is once again helpful. I understand now that it's not only due to bitrate, but your mentioning of using a 95MB/s card states that we would need a card at that speed???
If I am correct, I read in earlier posts that noone has had a problem with using a 45MB/s card, can you probably verify me on this?
@GH2_Fan @jvalal The SanDisk 64GB 95MB/s will run all the new patches and has the highest probability of spanning of any card tested so far. I have also tested the Delkin 16Gb 95MB/s and it has worked with every new patch in 24H (I have not tried Mysteron Burst) and generally seems to work in most other modes ( I would have to check individually, but it is my go-to card since it used to be much cheaper than the SanDisk option whether it is now or not). BUT the Delkin does not span the new Sedna, Orion, etc, etc.
At this point, those are the two brands and those are the cards we have the most test data on for the new patches with consistent performance.
Once again - the bitrate is NOT the only factor. If the max frame size is too large, it can also cause problems on slower cards.
I repeat, if you want reliable performance for the newest patches, makes sure to get a 95MB/s card (SanDisk 64GB if you want a better shot at spanning).
Also, not all Class 10 cards are equal. The less common brand mentioned seems likely to be a low performer but I am not sure. The SanDisk Class 10 cards are faster than usual, for the most part. Hope that helps.
@thepalalias yes more helpful. However, my card should handle that, it is a class10. Do you have a card reco that will work on these patches? I'm a newbie to some of this and just want things to "work". I don't have a ton of time to det into the details as many do on here.
@rigs then you are doing something wrong. As my reel can attest, the GH2 is great with noise, when used properly. OR you have a bad sensor. (it happens, which is why I recommend people not hack their cams out of the box. That they shoot with it a bit first to see if they have a bad chip, and if so, send it in for warranty replacement until they get a good one before hacking it.)
I know about the noise bug, as I said I always work down the iso range. I do have neat video and a bunch of other tricks. GH2 rez is real good but Man I wish it was better with noise.
@thepalalias Thanks very much for that informative post, it did indeed was more helpful. However like I mentioned before, I have lowered the bitrates to 50M and 100M to avoid this sort of problem but it seems it didnt help. I really like this patch as I'm all for quality but I definately knew I wouldnt be able to handle nor do I have space for 157M (if I'm correct).
When you mentioned that "the newest patches have not been designed for those cards", do you mean specifically my 7DayShop 32GB Class 10 card? or due to it's speed? Because after abit of research into my card, it has a writing speed of 20Mb/s apprantly.
So I would like to ask, is this happening to me mainly due to the writing speed of my cards? Or, the new patches just like Sandisk and more pricier SD cards??? :D If it's the former, what is the speed for a card to record video onto? :)
