How to make aperture stepless?
  • Konica Hexanon AR 40mm 1.8 is not sharp at 1.8 but very good at 2.8. It jumps from 1.8 to 2.8.
    I wanna make it stepless with good damping on the aperture ring. Can anyone shed some light on this topic? Thanks.
  • 19 Replies sorted by
  • I know this is a different lens mod, but you maybe can use the same idea for a cheap dampening solution: Works really well for me!
  • What about electronically controlled video lenses, like the micro 4/3 ones from Panasonic? AFAIK they are mechanically stepless, but cameras usually allow only 1, 1/2 or 1/3 stop adjustments. Making the adjustments in .1 or smaller stop fractions is a matter of software setting, is it not?
    Would such adjustment be possible to implement in hacked firmware, or would it be necessary to hack the lens firmware as well?
  • I guess stepless aperture is not that important. Also kinda risky mod.
  • Main FD problem is imho in spring around the aperture. Around f16-22 is the spring tension very high.
    Is that spring really necessary for aperture itself, or is it only used to transfer force between body and aperture?
  • As a low-tech approach to aperture pulls on my FD lenses, I use the adapter's "Lock-Open" mechanism. Switching this from Lock to Open disengages the aperture, sending it wide open. So, if you set the lens's aperture ring to the smallest aperture you want and then open up the Lock-Open ring on the adapter, you can create two different apertures for the pull and reproduce it pretty well. (It's more consistent if you're going from a wider aperture to a smaller one, but you can make either work with practice.)
    Not ideal, but not bad in a pinch.
  • I would like to know the same thing.
    The leitax guy uses silicone grease, he also sells it.
    http://leitax.com/
    The problem with my leicas is that it needs damping.
  • Which grease he used for FD, or what would you recommend?
  • Declicking Canon FD lenses :
    http://jag35.com/new/blog/removing-aperture-click-out-of-fd-lenses/
    Declicking leica: follow this steps just until you get to the ball. Remove it and reasemble.
    http://leitax.com/conversion/leica/elmarit-28-r-cam/index.html
  • Maybe remaining the ball and sealing the holes on the inside of the bayonet for having a constant pressure. This is a interresting topic. the cinemod of lenses is really expensive. This mod and a set of half inch rails zip ties and we are set.
    http://cgi.ebay.de/Half-Inch-Rails-Zip-Tie-Follow-Focus-Lens-Gears-gear-/290548711228?pt=Filmnachbearbeitung&hash=item43a60d7f3c
  • The Helios 44m i have has stepless aperture. I paid 15$ for it, and it's quite sharp.
  • >I don't wanna apply grease on aperture ring.
    This is good decision.
    But I offered to glue thin PTFE sheet (or 2-3, according to your lens) inside aperture ring.
    To make good dumping all you need is good friction, but not one that will stuck sometimes.
  • See the design pic.
    I don't wanna apply grease on aperture ring. Without a ball, it's pretty loose... the grease will leak.
  • No one could make it. Just try to look at original ball size :-)
    And damping is working good only having large surface.
  • Another idea. This could be a big hit... if someone can make it.
    Take out the tiny ball. Have a special metal piece w/ "half" ball end so that it can fit into the hole where the original ball was. The metal piece has built-in mechanical damping (e.g. rounded metal sheet) so that aperture ring has enough damping.
    640 x 478 - 91K
  • Sounds very complicated.
    May be try to glue thin PTFE inside ring?
  • Hmmm... drilling a tiny hole through aperture ring... a hole w/ thread... then a tiny screw w/ soft end might do it. But I need a machinist.
  • >to customize $45 lens
    In this case get screwdriver and start making conversions.
  • Yeap yeap. That's the hard part. I don't wanna pay $500 to customize $45 lens.
  • Stepless is mostly easy (disassembling rear of the lens to various degree and removing small ball).
    Damping is not so easy. May be try to put something to the inside in diaphragm ring? Never done that.
