                  I am using this for a while now ... i have noticed 30 min limit on my 32Gb 30MB/s sandisk card ... Is it because of 2fps setting or complexity or because original 30 min limit applied on the original Firmware ... How can i do ... say 2 hr time lapse shoot?
Hi guys, thanks for all the love you guys put into the GH2. Panny should acknowledge the work that's being done here and for moving so many of their GH2s out into the world. We really can't thank you enough.
I'm just trying out this time-lapse thing on my camera but unfortunately can't install the timelapser app on my Mac. I'm working in AE for now. Anyone managed to solve this?
Please find in below link a similar method of that what @GH13Timelapser has done for MJPEG. Tis method is able to handle AVCHD Timelapses.
@Vitaliy_Kiselev Just like @stockhausen I'm chomping at the bit for GF1 Xfps. I'd like to humbly add to the request for supporting the GF1. Thank you excellent sir!
@Hwulex , hi there,, Yes, after donating towards it I was marginally "miffed" as they say here, that pTool 3.64 didn't implement GF1 2fps,, BUT considering the crazy amount of work Viteliy had gone to It wasn't surprizing PLUS I had the foresight to invest in cheap GF2 body last dec and that does the 2fps beautifully so my Miffedness lasted mere seconds, if yr impatient and have £150-£170 to spare go GF2.. chomping at the bit will only wear yr teeth out :]
Can someone point me to this mpeg timelapser patch, without anything else. Just the mpeg changes, i'm worried if I use the Cbrandi 44mbs + timelapser, it may miff up some other settings i'm unaware of. (i.e how do I know driftwoods patches replace every setting of Cbrandins?)
So the solo timelapser mpeg settings patch would be very helpful!
All, What is the bit rates you are all getting at 2fps in mjpeg mode? I am getting only 6 to 7 Mbps. If I remove the 2fps setting, I will get about 50Mbps. I patched the 720 mjpeg mode to 1080 using the Low Light setting. I double checked my settings and reset the camera after patch. I also reformatted the card.
Here are the settings that I use (by LPowell):
720p30 width=1920 720p30 height=1080
E1 Quality=400 E1 Table=24 E2 Quality=200 E2 Table=36 E3 Quality=175 E3 Table=48 E4 Quality=150 E4 Table=4
Thanks
Sorry. I figured this one out as follow:
I was a little confused that the values of E1 through E4 set the bit rate like in AVCHD. But I think the values for E1 through E4 are different.
