A small request if is possible. Me and many other people use gh2 to shoot hdr Photo. To do that we shoot different photo with 3/5/7 different shutter speed. Sometimes is not enought the gh2 setup where we can setup to' shoot with 1/3,2/3,1 stop difference. Is possible to remap these value? For example change 1/3=1 stop. 2/3=2 stop. 1 = 3 stop. This can avoid a lot's of manual work.
It is very old request.
Right now I can't do it.
@madrenderman : Try this instead:
Remap the bracketing sequence from -/0/+ to 0/-/+.
This will get you 0,+1,-1,+2,-2,+3,-3 instead of -3,-2,-1,0,+1,+2,+3. It won't get you extra DR range but will get you the widest range (-3,+3) in the shortest amount of time (2 consecutive frames). I don't know if it solves your problem, though...
too bad, would be great to see maybe a +5/-5 range with the ideal two stop increment.
I had programmed a remote to be able to shoot multiple bracketing sequences continuously to achieve High Dynamic Range Video (keeping only -3, 0, +3 to merge), but was still constrained to only six EV range.
