Cheap anamorphic lenses for m43
  • 72 Replies sorted by
  • I have the Sankor and Helios 58mm. My problem is 35mm is really a nice focal length for anamorphic (particularly with our 2x crop), any solutions? How are you shooting the 20mm with anamorphic?
  • @madrivermoco My wife has a gf2 but is really hard to grab that camera with a lens + anamorphic attached to it. How do you even grip something that front heavy?
  • The GF1 with the anamorphic patch, a 20mm f1.7, a yashica 50mm 1.9 and the kit OIS lens (either 14-42 or the better 14-45) and the polaroid diopter pack with get you an anamorphic handheld studio for relatively cheap - haven't been ready to show any shots of that footage yet, but it's an easy, durable and usable setup that NO ONE notices...
  • Well, finally got out to shooting some and practicing this focus lens, focus anamorphic stuff. It is still a pain. But I'm on a very small budget.
    Thanks for the suggestions. I got an eiki since it was cheap and is exactly the same as the Sankors suggested by you guys and footage looks decent enough so thanks again!
    Here's some test footage I shot. Uploaded quality not the best since I don't want to pay for Vimeo Plus! :D
    Still no diopter. So no close focusing.
  • yep. i'm getting one!
  • +1 Tokina ATX Pro
  • Might be beyond your budget, but the Tokina ATX Pro 0.4+ Achromat Diopter is simply superb.
  • Thanks for all your input. I ended up with the cheapest anamorphic I could find. Eiki 16f Looks like I need a diopter for close range stuff. Focusing a pain. But if you focus to infinity on both lenses looks sharper than I expected wide open (I had very low standards after I saw how soft it was for objects 6-8ft away)
    4000 x 3000 - 4M
  • hi guys, can anyone tell me advantages and disadvantages about these lens:
    -ISCO 2x 35mm Anamorphic Lens Adapter - Gold CMATL -35NAP2-4 80-120 60/2 LOMO -SANKOR - ANAMORPHIC ADAPTOR - M LENS -SCHNEIDER-KREUZ​NACH 2/80mm CINELUX
    thanks.
  • Century 16:9 anamorphic works really well with wide angle lenses. It works perfectly with the 20mm pancake. The Kowa, Sankor and others will only works on 50mm lenses and up. It is like the LA7200 but cost less. Some of them have threaded mount but that it is very rare to find. Most of these lens will come in bayonett mount. If you can find one in thread mount, get it. The best value/performance lens out there.
  • @ipcmlr No, did not use any diopters.
  • beeldlab, love your work. Can you advice on focusing? I have the same Sankor 16c + Helios 44 + GH-2. Do you focus main lens first? I created a focus Chart to shoot, and found you can focus say in the vertical orientation while having the horizontal out of focus. Any tips would be appreciated.
    640 x 419 - 109K
    640 x 426 - 113K
  • Sankor 16c with helios 58mm stopped down to f2 first clip and f4 second.
    not my best flying of the glidecam. Windy and 58mm picks up any extra movement
  • @beeldlab Wow! Looks fantastic! Lot of it has to do with the camera operator! Btw. Did you use a diopter/closeup lens for these shots? Again this looks spectacular.
  • Sankor 16C is great. See
    and
  • If I remember right, the Sankor D is quite a bit older than the C, and therefore more likely to have issues.
  • How about the Sankor 16D? Any feedback on that? Basically the same as the 16C?
  • Andrew never reviewed the Bolex Moller 16/32/1.5x which in my opinion, is the finest non-Isco anamorphic you can buy. The LA7200 is a great all rounder and can be used down to 14mm with the Panny 14/2.5. Neither of what I've mentioned is cheap though.
    Ischico Proskar is the best cheaper option...I have two :-). Along with a Century 1.33x, Kowa Prominar 8Z, the LA7200 and the aforementioned Moller 16/32/1.5x.
    I use the Vid-Atlantic clamp, and the redstan front filter clamp, along with the Tokina 0.4 Achromat.
    Mounting the Moller is murder though, and the LA7200 was challenging too.
  • Thanks! Will check these out!
  • The first three expect to be able to use 50mm lens .. a little under. Check out EOSHD, Andrew Reid .. it's one of his specialties. And he has reviewed all of these lenses, except the delrama .. unless I missed it.
    And although 50mm doesn't sound very wide .. think .. I am shooting with a 25mm and it's going to be cropped .. aspect wise it's the same
  • All of the above require that you focus twice
    Even cheaper but useable and arty are the Delramas google them .... shoot through 1.5x You want the 16mm not the 8mm They also go as Vistascope (pretty sure that's it) I paid $24 on ebay
    I also have a century optics 1609-58 .. which are going up in price .. it's a shoot though 1.33x It was $600 direct from schneider (bad spelling) .. I negotiated .. they may still have them .. they had 8 when I bought mine.
  • Cheap and workable .. look for a Sankor 16C or a Ishico Proskar, both are 2x I think I paid about $150 AUD for each discovered in a local store .. you can find them on ebay for around $200-$250US .. don't forget you'll need to mount it.
    Under $700 look for the Kowa 16H .. I paid $550US on ebay
    Acceptable option http://www.ebay.com/itm/ANAMORPHIC-LENS-CLAMP-KIT-KOWA-SANKOR-SINGER-ISCO-/300569782054 .. this struggles with the Kowa
    I intend to get http://www.redstan.com/index.php?route=product/category&path=33 before I shoot anything paid with Kowa
    I bought them all about a year ago .. in a frenzy of excitement :)
