@brianluce, Don't have the Mk1- so can't tell... but the level is nice and hot...
I have the old DR100, does the Mark II record a hotter signal? I've always got my level dials way high for dialog, presumably this is because of DR100 music roots.
Make sure that you use NiMH batteries. Alkaline are useless for pro gear as they contain next to no power. I have used the MKII for over an hour with power to spare off 2500mah NiMH. They are also VERY cheap!
Great to have the built in backup power available!
So power up!
Just got delivery of my Tascam DR100 mkII yesterday. Played with it a little. Need to get to know it very soon as I will be using it on 2 shoots latter in the week along with a rented Sound Devices 744T. Will report back after the week end. So far the only down side is it eats up AA batteries with phantom power on (Duracel alkaline). About 10 min of recording time on just the AAs. Not an official test though. Hadn't charged the rechargeable so don't know about that one yet.
@apriori yes, this is one reason that I'm very keen on the MK2. The ability to keep the signal digital from mixer to recorder is awesome.
The DR-100mkii has a major selling point which hasn't been mentioned: S/PDIF input. Prior to the DR-100mkii, the most affordable digital recorder with an S/PDIF input was the Marantz PMD661, which retails for double the price of the Tascam at $600.
Although 2-track recording may be a significant limitation (2 channels are fine for my needs), I think the ability to receive external digital signals outweighs it. I plan to connect a Sound Devices USBPre2 with my DR-100mkii via S/PDIF output, which should allow for degradation-free recording at $950 total (Tascam - $300, SD - $650).
If you like the idea of using a higher end device as the front-end of your recording chain, the DR-100mkii offers incredible value. If you're looking for an all-purpose field recording device, the Oly LS-100 or Roland R-26 look great, and may be better options. (I can't attest to the DR-100mkiis performance as a stand-alone recording solution quite yet, as I'll be using it for the first time on a shoot this weekend.)
Yes. The Olympus LS100. I have not confirmed this as yet. Tascam's literature suggests the DR100MkII can record from both the internal mics in stereo and the XLR/Line inputs at the same time either in stereo with 2 mics or mono fed to both channels. Is this so? The Roland R26 can record to 6 mono channels or 3 stereo according to their add literature. All 4 internals and the XLR/Lines simultaneously. I will report more info on the Olympus as it becomes available.
You talking about the Olympus...? I am aware of this limitation with the MKII.
Could be except it supposedly only captures 2 channels at a time. It cannot record both XLR audio signals and the built-in condenser mic signals at the same time.
You have the new olympus LS-100 in between the Tascam and the roland r26. It seems to be quite good for $ 400.
Hey @digitaldooda,
I currently have the MK11. Can say that it is a VERY good unit. The pre-amps are VERY clean, and the unit is very well made.
Personally I use this for NTG3, and also for recording line out of theatre / music shows. Works very well on both occasions.
Let me know if you have any questions...
I am in the market for a field recorder and am very interested in this unit. Any one have any experience with the DR100mk2 yet? It sells for $299us at Sweetwater, 2 year warranty and free shipping. The Roland R26 sells for $499, 2 year warranty free shipping. The Tascam is a 2 stereo track recorder the Roland is 6 track, 3 stereo.
