ETC causing speed write problems
  • I have a hacked gh2 - using the "safe" eoshd vanilla hack - 44 mbs
    and using BOTH transcend 32 gb and Sandisk 16gb (30mbs) cards i get this problem:
    When i shoot in 720p 50 (i have the cam changed to PAl output to change from the factory 720 p 60)
    AND
    use the ETC for reach (this is on the Panny 45- 200 lens) - i get the recording stopped due to card speed error - the camera goes unresponsive and i have to do a hard reset - remove battery - to get it to work again. No Problem outside of ETC modes
    Should i try another firmware setting ? Or does ETC generally cause problems ?
  • 1 Reply sorted by
