Driftwood GOP1 AQ2 'AQUAMOTION v2' did give me some errors.
So i put back the Driftwood GOP1 AQ2 'AQUAMOTION' Experimental patch
And it did what it must do, working without any error.
Iso 160 to 4000.
Shutter 50 to 320, and lens from 14 to 150 and tele2.
Nothing special in the clip, just a lot of movement..
Dunno if it's V9b or not, but wanted to add that I had no issue playing back a single clip today in camera, and had done a mix of formats. 720/60P, ETC mode, 1080/24, ETC mode.
Good stuff.
What I think about noise and ISO. There are no true ISOs. There is the native sensor signal. Then before the analog signal gets converted to our 8 bit sample, a "pre-amp" boosts the signal based on the selected ISO. Anyone familiar with a transistor, a nominal signal is applied to the transistor, and a voltage is added to boost the signal on the output. My guess the amount of signal gain is controlled by Pulse Width Modulation PWM. And depending on the quality of the input crystal and the PWM, some "frequencies" of pulses to control the gain are probably "cleaner."
Hey guys! Heres a video I shot with the Aquamotion V2's 720 60p at 66 and 55 mbps. I am so very satisfied with Aquamotion V2 720 but it fails sometimes too. Sometimes it run perfect, sometimes i get the card write speed limitations. anywho, watch it for some slow mo rugby! :) enjoy!
Hi guys. Just thought I'd post something up from here in super hot and sunny Singapore. It's nothing much.. if anything at all. Just a video I shot during lunch to test Quantum v9b updated patch. No color correction or anything else added on. Just straight out of the camera and into edit and out onto Vimeo. Seriously, you guys are my heroes. Great great work done keeping the love for this small little camera. Thanks folks!
Quantum Lunch (GH2 + Quantum v9 Updated + Nikkor 50mm ƒ1.4D) from Hazrul Idzwan on Vimeo.
After seeing v9b, which came out the day we started shooting, I wish I has used 9b. These clips came in at 88Mb/s. We've done one P/U shot for the film so far with 9b...and it looks amazing. And the 9b clips are coming in at 149Mb/s. Driftwood is my own personal Jesus Christ.
Bravo, looks great.
that looks real good, and the music is Wow, all those things together.. good job
shian, looks great.. Nice job all around.
@shian wow now that looks great! i read you said that sampling white balance create noise, what about auto white balance is it cool to use it or it also creates noise?
wow! was there a special skin tone treatment? looks like a subtitle highlights glow ...
@mozes Yeah, our composer, Christian, is pretty badass.
@Swiss_Boy @Alex I always seem to get in trouble for "shameless self-promotion" when I cross post - even when its relevant, so the details of the shoot are in the ColorGHear thread, where I posted them last week http://www.personal-view.com/talks/discussion/1817/colorghear-toolkit-color-grading-system-for-ae#Item_348 But the smooth skin tones is a special application of ColorGHear's GHrain Killer. There are some before and after stills in the thread.
There was a really nice grain on the v2 footage, not as nice as 9b, and I only treated it in spots for effect.
And Swiss_Boy, I only encountered noise when trying to sample for WB, so I've gone back to dialing it in the way I've done from day one. I see no need to sample, or auto WB ever again. It's not very hard to figure out what color temp your lights are and adjust for it (and/or gel them to get them where you want), and then save it as a preset. I haven't done any kind of scientific test on the subject because it hasn't been a big enough problem for me, and one easily avoided.
Just like the ISO bug. I never use the 3rd stop ISOs only the full stop ones 200, 400, 800, 1600 and 3200, I do all my in between exposure adjustments with scrims, dimmers, gels, and moving lights closer or farther away if necessary.
Does anyone know if there's a way to combine the 720 60p settings for Aquamotion v2 with the 1080p settings for Quantum 100?
@shian Hey thanks for the fast & instructive response. Yea i know you can save 4 presets of white balance but i'm not sure that if you can also save the one where you set the colors vector + K number the last one on the right so i will have to check that. And I think i will also start to use the full stop Iso but i find this video where it shows that iso 640 is kinda good
*** NEW *** Driftwood Quantum v9c AVC-HD INTRA100/50
A new experimental patch before the new ptools release. This has been tested on the original AVC Intra 100 matrix which will be available in the next version of ptools. For now its enjoying the base camera matrices. INTRA 1080p = 128M averages around 100M INTRA 1080i = peaks quality is around 100M INTRA 720p50 = peaks around 100M 720p60 now on GOP2, peaks around 100M.
In particular want to know if this spans.
Let me know how you get on in real world recordings. Graphic below shows an unusual GOP2 on 720p60, as INTRA for this mode only works for 3 seconds - but attempts to stabilise GOP1 are further underway.
Enjoy,
Nick
Did the most strenuous test I could this morning before work:
Panny 14mm, autofocus continuous left on, filming television full frame with the worst card I have (ADATA class 10 32 gig). Did two tests, one at ISO 160 one at 640 -- the main two iso use. Both failed to span. By way of reference, Aquamotions span fine on this card. Although weirdly the files show they get up over 4 gigs before failing which makes me wonder if there is something there that can be recovered.
Ran tests again with Sandisk 30mbps (extreme video cards). Spanned no problem at both ISOs.
Mac based so sorry, no stream parser.
Thanks again for the continual improvement of these. Nice to know all my 30 mbps sandisk cards won't be gathering dust!
(as an aside, can confirm the minor difference in record times with different isos -- 8 1/2 minutes for 4 gigs for iso160, compared to 6 1/2 for 4 gigs for iso640).
EDITCard used was SanDisk 30MB/s 32GB HD Video Extreme (apologies)
Just done a quick test with 9c. Used Panasonic 14-140, shot at telephoto end, ISO 640 f.9, ex tele mode engaged, stopped recording at 3.99GB. File wouldn't play back in camera, had a read error and now no valid image to display.
Good to have you back though Nick. I'll keep playing with 9c, but there are certainly a lot of people on this forum that are better equipped to test than me. Keep patching mate, my hat remains off to you.
Your little AE set of tools are great! And the tutorials are very informative. I'm an amateur when it comes to cc & grading, but I like the results you can get very quickly. "What Lies Between Us" looks really good, congratulations.
@ignatius -- can you edit your post to include what card you used?
Thanks man! No worries -- was just curious :-)
Quantum v9c real world quick test.
Cam setting: F6.3, 1/640 and iso 160
sandisk extreme HD video 32gb 30mb/s
720 50 fps full zoom incl with tele2, error after 5 sec. file get saved..
720 50 fps full zoom error after 4 sec, file get saved.
50i, all went well til i stopt the recording.
LCD freeze, i had to remove the batteries....
auto quantizer is not enabled, is that supposed so?
Initial impressions on Quantum 9c...
Clips spanned at 24h and 720SH on a Sandisk 64gig 95Mbps card. Three times at 24H and twice at 720. I stopped the recordings both times because I need to leave soon. Ran these tests using the "kit lens" 14-42mm, image stabilization on, sweeping motion all over the place with very detailed scenes.
Image quality looks very similar to the Quantum100 patch -- to me. It doesn't kick me in the face like 9b, but it certainly looks good enough for serious applications.
Windows 7 reports "total bitrate" of 78927 kbps on the 24H and 57709 kbps on the 720SH.
my 2 cent, thank you driftwood !!!
Tested on 24H V9c Leica 25mm/F1.4
shooting on bookself
1st attemp
Sandisk Extreme Pro 32G 45MB/s (1) 6:37 2.7G on 58636kbps stop by me
2nd attemp
Sandisk Extreme Pro 32G 45MB/s (1) 7:15 3.99G on 78678kbps, span (2) 7:15 3.99G on 78506kbps, span (3) 5:40 3.12G on 78582kbps, stop by me
shooting on wooden window
1st attemp
Sandisk Extreme Pro 16G 30MB/s (1) 12:30 3.66G on 41724kbps auto stops, no span
2nd attemp
Sandisk Extreme Pro 32G 45MB/s (1) 12:30 3.66G on 41632kbps auto stops, no span
The behavior seems differently than V9b, is it because no configuration on Auto Quantizer value ?
Nope. Nothing to do with that. This patch is purposefully left on 20/20/20.
Here, I am using AVC-Intra 50/100 spec bitrates, logical memory usage video buffer control, frame buffers from AVC-Intra spec , fb2, and frame limits all combined for stabilising AVC INTRA rate control. This is not the final version of this setting - purely experimental until the new ptools comes out.
I have been playing with special Intra matrices and a few other bitrates / coded picture sizes borrowed from AVC Intra. Of course, we can never replicate AVC-Intra 100 in its purety as that is a 10 bit 4:2:2 implemtation, the GH2 is only 4:2:0 8 bit. But we run it bloody close, and its looks good with tighter Q and the ripped AVC Intra 100 matrix to provide the closest colour implementation we can get to the Panasonic spec.
This means, all being good, that the final Quantum AVC Intra patch (when its released next week) will mix well with camcorders using the P2/AVC Intra specced implementation.
It won't be 100% but its close - my own findings have shown close resemblance to the AVC-Intra 100 footage but don't forget 10bit (1024 colour space) offers 4 times the colour space of 8 bit - 256 shades in the range (8 bit is responsible for the poor colour gradations seen in particularly in blue skies, etc...)
Later tonight a test patch of AVC-Intra 50 settings will be released in Quantum 9d (Quantum 50 v2). Remember, these are test patches for you. Don't treat them as final BUT give me feedback.
I am withholding my Q settings until the next ptools comes out sometime end of next week.
@mozes Thanks. I havent given 720p50 any kind of runout like Ive given 60p. But that will be primed for next week's release as it works better with the INTRA matrix from what Ive seen. Remember we're having to use Panasonic stock matrix in Quantum v9c until the new ptools arrives.
is quantum v9b much improved over seaquake?
all the talk is about quantum these days!
