Fancier FC-470 tripod
  • 33 Replies sorted by
  • In terms of the lack of weight, what if one was to use a 4kg slab of iron mounted under the gh2, do you think that would allow the counter balance to work properly?
    I know people that are doing precisely that. Yes it works But it's inelegant.
  • Yes. But this must be balanced (so, no weight on one side). The higher you place it, the smaller it can be.
  • >a modded Fancier
    It won't be modded, if all goes good as planned.
    It'll be just different head made for DSLRs. With changed counterbalance and may be other few things.
  • I did some research on the best tripod to use for lightweight GH2, for shooting in a stripped down mode, ie no monitors or tons of accessories attached. As Vitaliy says, issue is camera is too light for find good counterbalance. The Libec line is rated highly in general terms -- and some units compare with Sachtler. It's considered a very good value for the money. I called the Libec rep in USA and discussed the specs of the GH2. Finally arrived at the DV22, that, according to the Libec tech is the best match for GH2. Well I bought it, it's only about $300. But after using it a bit, I think it's nothing special and kind of sucks. Flimsy legs, wobbly head. Mediocre on a good day. As far as I know, only the Vinten Blue is great for GH2 but it's expensive -- over $1000. So I think the best hope for something affordable is what's posted here, a modded Fancier. Hope so.
  • It looks like they could make head modification for DSLRs.
    Hope to get details about first sample made for me.
  • I hope to get news soon from engineering team about counterbalance and making of special modification of this very good head for HDSLR users. Stay tuned.
  • Small update considering Rokinon 35mm F1.4.
    This lens it fuckingly amazing.
    Absolutely useful and sharp at F1.4 (despite noticeable abberations, but they are easy to fix in post).
