@Vitaliy Any chance to enable (with the hack) the battery life indicator for 3rd party batteries in this new 1.1 firmware for the Gh2? Thank you Mike
the battery indicator is not depending on GH2 but is a battery issue. If it has something called "chip" inside or not. Many sellers in the description include this information.
today i receive this 2 batteries http://www.ebay.com/itm/130542457807?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649. Almost 90 minutes of recording HBR mode 25p PAL with one battery. Very satisfied and for maximum safety i will use the non genuine batteries for half an hour each and the genuine for long term!
I am pretty sure third party batteries killed my first GH2. I am not using them anymore. No indicator when you shoot video is also killing. It breaks the AVCHD index, you miss footage... too many reasons not to do it. I have read multiple reports of broken GH2's and most of them were using third party batteries. Just my thoughts.
I am a bit concerned about these 3rd party batteries damaging my GH2. Vitaliy says they should be ok. Thanks for you info Sohus, do you have any links where i can read these reports of batteries killing GH2's ?
Vitaliy_Kiselev May 2011 : " You can damage your camera with some bad battery, yes. Probability is very low, but you can. I think it happens due extreme discharge and very high temperature of the battery elements. I do not think that it will be happening with GH2."
@wangc try wasabi battery for your HF100, fully decoded and accurate battery metering in cam. Wasabi have GH2 but NOT decoded, probably the quality is good. http://www.amazon.com/Wasabi-Power-Panasonic-DMW-BLC12E-DMW-BLC12PP/dp/B0051PLPM6 This one claims to be decoded but is only 1200 mah http://www.alibaba.com/product-gs/427356289/Camera_battery_for_For_Panasonic_DMW.html
And (are you sick of battery) this claims 1600 mah (!!!) plus decoded (!) OK I will buy one http://www.ebay.com/itm/2X-DSTE-1600mAh-DMW-BLC12-BLC12-Battery-Panasonic-DMC-GH2-GH2-Free-shipping-/280798897859?pt=Batteries_Chargers&hash=item4160eb26c3
Problem: Because the GH-2 won't shut off to indicate battery is low. The battery just discharges below operating voltage. Internally the battery has a safeguard that turns off the output voltage when it drops to a certain voltage. Here is the problem. The stock charger reads the battery as zero volts. It can be charged. you will get the blinking green light. Charge for a while. remove, charge again. then your seemingly dead chinese battery will be fully charged. I have two and they are fine. Other option is to switch out batteries after some shooting so you never drop the voltage too far.
From user @lsf2000 in a different thread: http://www.ebay.com/itm/280798897859?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 "Now This Battery Can show Battery level In Your Camera" Has anyone tried these?
I think we should wait for DrDave's tests about them. In his post above he says he wants to try one. The price is worth a try.
hah, I didn't even see his post in all my excitement.. where the dunce hat at ?
I was not able to snag this battery as they all sold out immediately. If anyone has one, please report.
Darn! That took me by surprise as well. I wrote the seller asking about it but he pointed me to other batteries they sell that don't declare to have such feature. I replied that I was looking for that special feature. And that was it.
the word we have to search for is decoded- then the batt indicator will work. this site claims to have a decoded battery: http://www.ecvv.com/product/3141676.html
edit, also found it here: http://www.diytrade.com/china/4/products/9005220/New_decoded_for_DMW-BLC12_replaceable_batteries.html and here: http://www.ecplaza.net/trade-leads-seller/new-decoded-for-dmw-blc12--7668109.html
Good to know, thanks Fatpig. We only need to find some retailers since the sellers you linked only sell large quantities.
The seller (the recently sold-out ebayer) shipped me a pair two days ago. if nothing else turns up, I'll let you know in like 25 days if it works as advertised. In the battery grip-thread, @lsf2000 said he had two, and another two on the way. I PM'd, asking to confirm if they work properly.
