Questions about Using the TrustMT Cage
  • Can you have full access to the GH2 battery compartment?
    With one of the vertical supports removed (for LCD flipped out or HDMI clamp) does the cage flex?
    If I don't get the base plate for rods, is there a clean way to mount a tripod plate directly to the bottom of the cage?
    Right now, Letus is selling the Talon for $399, BUT it looks like it does not accommodate the LCD swung out (has all four vertical pieces in place) and I read somewhere that it does not allow battery change with GH2's.
  • 1 Reply sorted by
