Official Low GOP topic, series 4
  • 586 Replies sorted by
  • @f1lm3r H setting? Did you try the L setting for that card ? Thanks for testing mate.
  • @driftwood V7's 24p crashes my 16gb 30/Mb/s on stray's death chart, but the 1080i/720p does not.
  • @driftwood
    I did the instant test. The upper is what was shot the same interior of my room as usual, and the lower applies the stress highest with the Stray's chart. The typical I frame is chosen and compared in all. This result is very interesting. Is the maximum macroblock size taken? Is the lowness of average qp taken?
    Since my "megaMAQ2" is going to realize the lowness of average qp using big frame size, if the same concept is applied also in this comparison, it may be able to be said that the result of right-hand side is the better. However, in the frame size same at the same AQ, when so big the difference did not come out, I felt.
    NOTE: Since span became impossible when your bit rate arrangement was applied to AQ4 of me as it was, FB value was also made slightly down to the same as QT7.
    1349 x 1691 - 481K
  • @CinemaChico The bug and bird shit is insanely good... Nice!
  • @driftwood OK! I'll try. :-)
  • @kholi, only the 64GB 95MB/s disk is "XC-1", 32GB and down are "HC-1". I don't own these, can not comment. Best regards, http://www.personal-view.com/talks/discussion/1491/95mbs-sandisk-extreme-pro-spanning-reports-64gig-sdxc/p1
  • @driftwood Just gave Quantum v7 a run all I can say is WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the motion is soo filmic, love the grains, and finally quality soo clean and sharp without the Videoish qualities Great work...
    GOD Bless
  • NTFS icon comes up but youre right its not. wiki states 'exFAT can be used where the NTFS file system is not a feasible solution, due to data structure overhead, or where the file size limit of the FAT32 file system is unacceptable.'
  • no, it's not.
  • exFAT is not NTFS.
  • @driftwood: interesting re exFAT.. I'm going to try and reformat a sandisk 30mb/s card and see what happens.
  • @bkmcwd Give that bitrate setting a test on your GOP3 patch for me and let me know how the Quant matrices look in Elecard Streameye. Thanks mate.
  • I'm really curious... there are 8, 16, 32, and 64gb Sandisk Extreme Pro Cards (95mb/s) selling...
    And at reasonable prices.
    has anyone just not used them at all?
  • Its certainly strange, though I havent tried any less than the 64. I do notice when I boot up in PC mode on my hackintosh the external card reader sees it as a EXFat (NTFS) drive (not fat32). On another note: I also use Sandisks new white USB3 card reader - which seems much more reliable than some of the other card readers Ive used and may be a solution for people having read problems. Some say the top end Delkin cards (still waiting for my review version!) are spanning on the hi bitrate stuff... I think we need a wiki table of working cards building eventually. I think its important to remember to format these cards on the camera and not ruin it by formatting at ANY time on the PC which probably overwrites the hidden Sandisk SDXC-I headers (certainly on a LL Format).
  • @driftwood Okay great. I am going to switch over to V7 when the GH2 gets here, was just checking.
    Also, I haven't seen much info on the SAndisk 32gb 95 cards, which are a bit cheaper than the 64gb but I assume there's a reason why everyone goes for the 64? Do the 32's just not span or aren't achieving constant data rates?
  • @kholi in simplistic terms, I'm trying to guarantee more success rate of Q using matrix T1s for INTRA, and not any fallback matrices.
  • What visible difference are people seeing between V2 and V7?
  • @driftwood Nick, any guideline on how to trim Quantum v7 for Transcend Class 10 cards? I adjusted the frame limit but I got lots of card speed limit errors while shooting, in both L and H. I have been using TerraQuake lately, but I would love to have AQuamotion for the L setting for interviews and long takes.
  • @driftwood i know it has to do with that, i meant -in what situations the Quantisation improvement would be most evident ?
  • @rozroz, in Quantisation.
  • @towi in Quantom V7 24H AQ4, where WILL we see a difference VS lesser patches?
  • That's a lovely shot @FGCU
  • @FGCU Very Nice. Any chance in previewing the .mts file. Really I'm not stalking your fiance! ;-)
