From Pianoteq 3 to 4, three years of research were necessary to refine the physical model that describes the hammers, the strings, the soundboard and their interaction. A grand piano Steinway D from Hamburg has served as reference. Its main characteristics have been used for feeding the physical model from which the new grand piano D4 is born.
The secret of its sound quality lies in the refinement of the soundboard model and its acoustic radiation field computed via a structural analysis model coupled to integral equations. Moreover, each note has been carefully adjusted in its finest detail, just like in a real factory.
A new and exciting convolution reverb unit simulates acoustic surroundings ranging from Studio up to very long reverbs like Cathedral and Taj Mahal. It includes other types of reverbs as for example Plate, Spring, Broceliande… You can also load reverb impulses to set your own environment. In conjunction with these reverbs, the new D4 offers a sound quality that is comparable to a real recording of an acoustic piano with the best audio equipment.
New effects that benefit the electric pianos but also other Pianoteq instrument are included, such as delay, chorus, flanger, amplifier and compressor. Also included is a mallet bounce effect, especially adapted for the chromatic percussion add-on instruments (vibes, xylophone, marimba, cimbalom…).
Pianoteq 4 new features:
Xhun Audio IronAxe
Anckorage Spring is a physical modelling audio synthesiser based on the simulation of a set of connected mass- spring, integrating non-linearities, fluid and static friction, mechanical limits, gravity and bouncing. It is designed to be controlled by a continuous controller (like the Haken Continuum www.hakenaudio.com) but can be used with a regular keyboard or directly from the device screen or from other core midi apps. Of course a continuous controller will provide a much more accurate control of the model.
Features:
See more at https://itunes.apple.com/app/anckorage-spring/id647714831
Pianoteq 5
We have devoted two years of research to developing and refining the award-winning Pianoteq physical model. Pianoteq 5 brings a new clarity and authenticity to the piano sound. Moreover, it offers no less than 9 new piano models, and sound recording is taken to a higher level of control with the addition of directional microphones, letting you choose from a range of well-known microphone brands.
Here’s what’s new in Pianoteq 5:
Applied Acoustics Systems announced String Studio VS-2 for Mac OS X and Windows.
