GH2 Stutter/Judder/Strobe issues discussion
  • 218 Replies sorted by
  • @JackBayer Care to post some sample footage? I'd be interested to examine it.
  • I have this strange feeling that somehow the different patches may affect the timing of the cam taking the original frames. I might be wrong, but jitter in this place would explain alot. Is this possible?
  • @jackbauer interesting. In your experience, which hack provides less studdering?
  • HI all,
    as I sadly just had to realize the studdering varies alot between hacks. The latest Flowmotion is horrible to my eyes for example. Is there some way to post-fix it or bring it down at least?
  • Interesting, but I don’t see much difference in their test footage (aside from the rotating disk example). The judder is still there.
    Also, it turns out the Arri Alexa Studio also uses a rotating shutter: http://arri.com/camera/digital_cameras/learn/alexa_faq.html
  • A rotary shutter is not eliminating the effect, it even induces it on analog film too, albeit to a smaller degree. It needs time to rotate, so it will open one side of the frame first, then gradually open the rest, finally gradually closing again. Main difference to electronics: the edge of the shutter is out of focus and smeared by motion, that makes a difference. There is a company trying to mimic this for digital cameras:
    www.tessive.com
  • @Blackout1 I’m going to have to disagree with you. I don’t see how fading helps with smooth motion. As far as the film frame is concerned, you’re just exposing it for 1/48th of a second, the entire area of the frame. Digital sensor readout (CMOS), on the other hand is not instantaneous and even the fastest sensors are a far cry from being “on and off in a perfect fashion.”
    I think the excessive amount to judder in digital cinema has more to do with its availability to the general public. The sheer number of amateur videos shot at a “magic” rate of 24 fps outweighs the number of films shot professionally. Hence all the judder/noise/which-setting-is-better discussions.
    By the way, a few months ago I did some cursory reading on the subject of judder, and was surprised to see the same discussions on the RED forums.
    You’re right about the panning speed rule being very old. It predates digital cinema by a few decades. The reason it became a rule (well, a guideline, rather) was because following it created smoother motion.
    Someone posted a short clip recently (with one of the newer Driftwood settings, I believe) demonstrating a perfectly smooth pan. No judder whatsoever, an extremely filmic look.
    Here’s another thought to ponder: given the size of Arri and RED cameras, it would be very easy to implement a small rotary shutter in them. Heck, you could even have it at the same 45º angle as in film cameras! Then you could synchronize sensor readout with the shutter’s rotation and presumably get the same look. And yet neither Arri nor RED has implemented such a feature. Why haven’t they done that?
    EDIT: Well, I’ll be! It turns out that some manufacturers of digital cinema cameras do use a mechanical rotary shutter. The Sony F65 has one, for example. The purpose is to eliminate (or at least to alleviate) the rolling shutter effect.
  • There is something in works for this, a kind of LCD shutter.
  • @Blackout1, that's interesting info and makes a lot of sense. I think that a digital senor could simulate this by ramping the sensor gain at the start and end of each frame capture. I don't know if current sensors can adjust their sensitivity that quickly, but if not it will probably be possible in the future.
  • It is and has always been known that "digital" 24p will always appear to strobe and stutter because of the process in which it is captured. Regardless of the camera. Film shutter gates open gradually creating a slight fading for each frame. It fades as it opens and fades out as it closes. Digital cams are on and off in a perfect fashion. It is a rule of thumb not to have anything pass through the frame faster than 5 seconds to avoid this. This is a very old rule.
  • I recently became interested in the "judder" issue when panning in 24p mode. Recently got the e-image/fancier FC-04H Mod Fluid head + CT7402 legs deal off the site and really started noticing the juddering motion during slow pans particularly...thought I'd share my research on the issue.
    Btw if anyone wants to test for themselves just slow pan with any decent fluid head tripod past a bookshelf. The text on the book spines will "vibrate" and jerkily "judder" past on the horizontal plane. I would urge anyone unsure of what judder is to do this at 24p. Then compare to 50/60p.
    Do not confuse this with tearing (where the top half of the screen seems infront/behind the bottom half - check your v-sync options in your gpu) or strobing caused by a bad camera frame rate and ac mains powered lights Hz combination. Judder can also cause a kind of strobing in my opinion (as the details in the image/light seem to pulse as they pass the camera)
    Anyway to sum up "judder" looks like a 24p issue rather than a GH2 issue. Google 24p motion judder and check out the wealth of info in the subject. Some Blu-ray and projector combos make for some extreme motion judder artefacts apparently when watching commercially released movies.
    Some cheaper HD cameras seem to judder more than others however. The jury seems out on exactly why but as mentioned earlier in the thread, sharpening each frame (and therefore reducing the natural motion blur) seems to make things worse. This could be the issue in GH2. Other issues such as playback monitor refresh rate seem to increase or decrease the perception of the effect, in some cases masking the issue until the same footage is viewed on another screen/refresh rate.
    Blurring in post and shooting out of focus both seem to reduce the effect pointing to increased sharpness/contrast exaggerating the effect.
    I'm shooting with sharpness and contrast at -2 with a Canon FD 50mm. I can post some examples if anyone is interested.
  • I struggled for weeks to correct a noticeable pulsing or strobing on high detail, high contrast scenes such as tree branches against the sky (present even with only slight, slow camera movement). The normal judder of 24p also looked exaggerated. Having poured through this thread and many other sources, I couldn't find a fix (maybe I missed it). Last week, however, I read in another forum that turning off IR (intelligent resolution) was key. So now with most settings at -2 (contrast, sharpening, color, NR) and IR off, I am getting beautiful silky smooth 24p with the latest high bit rate patches.
    If you have tried everything else, but not yet tried this, I would highly recommend it.
  • @paglez
    Thanks for your reply. I am in PAL land. Still trying to get used to the best way of shooting with my new baby.
  • @JamesFinlay
    Probably you're shooting in PAL area with a shutter setting lower than 50. Try to set shutter speed at 50 to get equal value than light frecuency (50 hz)
  • Hi guys,
    I'm new here so firstly many thanks for all the hard work in making this an invaluable resource for GH2 users.
    I hope this is the right place to post this, someone reported similar problems here but then the focus seemed to shift more towards an issue of stuttering when panning.
    I bought my GH2 last week and installed 'reAQuainted' INTRA GOP1 176M. I'm experiencing some strobing effects on the video. It does not seem to occur on every shot. I am able to see the strobing in the monitor so I know when it is going to happen but as I'm very inexperienced with the camera I'm not really sure what is causing it or how best to avoid the problem.
    I'm using an Auto Revuenon 1.4 55mm lens with an M42 to M4/3 adapter - faster lens than the kit. The strobing seems more apparent when wide open at 1.4. I have not seen the problem on the kit lens but will test more to see if it occurs.
    I've uploaded to vimeo to try and explain what is happening.
    Sorry for the shaky cam on a few of the shots.
    Many thanks for your help.
  • What i can't understand is why Apple OSX don't give the possibility to change the Hz. of the monitor manually, for example in the cinema display or in a iMac display, incredible.
    I found a special software to do this SwitchResX but PLS Apple think also at the many people use the mac for video editing and don't have money to buy esternal dedicated 50Hz. monitor.
  • Meaning you've not seen any difference?
    That really matters if so!!
  • Ive shot at 25 shutter and didnt notice any probs.
  • Shooting at GOP1, does it make sense to shoot a shutter 25, would it make a difference compared to a higher shutter speed, 50 etc? Since latest developments by the Nick Driftwood, this question bugs me a lot. have not done tests yet, but in theory how it should behave?
    Thanks for the input everyone!
  • Hi,
    I work in the film business and I own a GH2 too. I also noticed the strange 24P behaviour when you are panning. I have made many tests and read many postings in a lot of forums. Believe me, no solution will work or solve this 24P problem. You are not able to get useful pannings in the GH2 24P mode. Any further discussions are senseless. I know that under some circumstances pannings seem to be O.K....But there are also a lot of situations where panning looks really awful. Sorry, but this is a GH2 problem only Panasonic can solve. By now I pan with 80% speed (unfortunately without sound) and interpret the footage in After Effects or Premiere as 30P-Footage. Then you will have smooth panning, Thats the only possibility. To get 25P, use After Effects and slow down the clip to 80%. After that you have a 25P clip without stuttering. 30P to 25P conversions works only in After Effects without stuttering. Many other editing programs promise to do the same...But I get always very bad results.
    I know that it is hard to realize. But if you want a professional panning in 24P you should try another camera. For me it is ok. I know what I can do in 24P and what not. For necessary pannings I use the 80% mode.
  • If you exported H.264 from FCP, it might be the culprit. It's not really good, try x.264. But, as Killagram wrote, I'd always prefer ProRes for a master file.
  • If the judder isn't present in the MTS file then the camera or settings isn't to blame, it's your export transcoding from Final Cut Pro. Try using ProRes or another algorithm to prevent this from happening.
    Using driftwoods IntraPure settings will give you more latitude while grading within an NLE as well as a much smoother appearing frame rate (all while keeping a high level of detail). If you have a fast enough SanDisk or Transcend class 10 card w/enough space, go for it. Just render the result in another format.
  • The orginal file, as viewed in final cut does not show the stutter, but the .mov exported from FCP has it, and the vimeo version is just a little worse. It seems that the stutter comes in when the person holding the camera steps to turn... and the pan picks up just a little more speed...
    I haven't tried the driftwoods IntraPure hack and don't know much about it. Our camera is from late 2009, so I think it would be compatible.
    The problem is that the gas well flaring video is a rough version of a much longer documentary that we plan to release in Jan/Feb 2012 and I'm trying to avoid the stutter on anymore exports from FCP, but not sure how to go about doing that...? How would driftwoods Intrapure help to avoid that problem if Im not seeing it as is in FCP?
  • @PublicHerald did the original MTS file have this judder or did Vimeo's encoding compress the everliving shit out of it and make it stutter? Have you tried using driftwoods IntraPure hack on your GH13 (if it's compatible)? If you pan too quickly you're always going to have some sort of encoding byproduct rear it's ugly head. Doing it gradually as demonstrated in your video should be fine as long as the sensor and recoding codec are up to snuff.
  • I've read through most of the discussion here and have noticed the "judder" (I think) in one video I recently uploaded shot with the gh13, 108024p, 14-140mm kit lens, stabilization on, panning with a shoulder rig. The stutter issue appears in 00:54 to 01:09...
    How do we work around this problem? Is it just the LCD of the computer?
    Oh, thanks for all the helpful input in this forum :)
