Now that the new firmware is released - I want to make a video in 25p, that features both normal speed footage and also in slow-motion (not drastically slow).
@Meierhans Yeah for the time being I'll just use the new timeline, and go by your advice. So setting the speed of the 720p50 footage will disable frame blending? How much will it affect the speed?
In the moment you can not record 25p (new firmware) and use the high bitrate patches (old firmware). This might change in the next days however.
If you don´t wanna mess with details and are happy with medium quality (for web delivery f.e.) just use the new firmware. Record 1080p25 & 720p50. Trow the 720p files into timeline, scale them to match size, set speed to 50 %, disable frame blending.
@Meierhans So as for the slow motion - with both 1080i50/60 or 72050/60p, do I drop them in the 24p timeline along with the normal speed 1080/24p footage? It will automatically be in slow mo if I do that?
If that's the case, can't I shoot 1080/25p for normal speed, have a 25p timeline - and drop either 1080i50/60 or 72050/60p into that?
I would wait with the updating, record in 24p quantum, conform to 25p (nobody will notice..). Then use either 1080i50 or 1080i60 or 720p50/60 for the slomos. 1080i will give you more horizontal resolution, but only about 540 vertical. 720p.. well.. its 1280*720.
Make sure to set the shutter twice the value you used for 24p, so if you shot with 50 before it should be something around 100.
If you plan to use Twixtor or similar use the shortest shutter you can get with your lighting, make sure your background is alot different from your subject. Use Reelsmart Motion Bur in After Effects to add motion blur later.
otcx meant to say: after you've slowed your 50p footage down to 25p, you can try to slow the result down even more using software like twixtor. but this has mixed results. most of the time half the speed is slow enough. :)
well, i suggest you would shoot one in 108025p and one in 720-50p - thats common. and also the only viable option, since without the hack you cant shoot 720 -60p.
