Like many of you, big fan of Panasonic's GH camera line, going as far back as GH2 (hence how I created my username).
However it has bewildered me that no-one worked on the GH5 like how work was done on the GH1 and GH2 i.e. dumping the firmware to reverse engineer it for tweaks and patches.
I know the GH5 is pretty damn good out-of-the-box but myself and many others here would agree there was always room for improvement. I've always been hopeful but manjy years has passed and still I can't figure out why.
May I ask anyone here to elaborate or share their thoughts on this?
Really cool.
Are you sure that you are dumping firmware and not just NAND settings?
As on previous cameras main NAND chip had been sandwiched with CPU.
Just an update, I did a firmware swap on the broken aliexpress GH5 board I bought and it works now, but i still need a firmware dump of the GH5 as it does the exact same thing with both GH5 PCB's confirming that there is a problem with the firmware image.
I filmed a video of the process and uploaded it to youtube.
I have two GH5 pcb's with firmware i dumped from both's NAND flash. One of my GH5's is partially bricked i think from a botched firmware upgrade (not entirely sure though) the other GH5 pcb had errors in the NAND but was still able to be read (errored when writing to though) Is there any chance the firmware is keyed to the PCB? Is it possible to perform a NAND swap on a GH5 PCB? I'm about to experiment with a NAND swap but seeing as how the firmware is encrypted i'm wondering if its also locked to a specific camera's serial number. I've been milling around the D/Led firmware from the website and comparing it to the firmware stored in the camera and it appears the one stored in camera is heavily encrypted. I'm not a programmer by any means but i have access to all the tools to read/write NAND flash so i wanted to take a crack at trying to fix one of these GH5's.
With some effort GH3 could be possible. I have almost full dump, as I told. But it turned out to be too much work with too little probability to make something significant and useful.
As for later models - doing dumps is wrong way. Instead we need to change society to have collective open source work on such complex things.
Dear Gh2 fan.
Thanks to gh1 the gh2 was born, then Gh3 was born after, and gh4 then gh5 now the gh6 and most probably a last gh7 as a final goodbye to m4/3 support from panny, but I doubt it.
What is the moral of the story?
Many baby’s can be born from a single gh camera.
And what’s the moral of that ?
It’s something to think about and reflect metaphysicaly. Go beyond and maybe you can be the chosen one to unlock the power of gh5 encryption problem. Maybe it’s not just a hack maybe there are more parts of it and for it.
You must go alone we shall wait for your return. Go Padawan !
Remember!!! the hack is in you! Lol
