I've installed Sage's latest patch. And I did some recording at the 24H setting which is Quantum v9b. When i try to use log and transfer to bring the footage in, it just keeps saying unrecognisable file structure?
I've imported Panasonic P2HD 100mbit avc intra before no probs, so i'm assuming bit rate has nothing to do with it.
Are other people experiencing problems like this with their GH2 footage? I cant seem to find many others experiencing this
Ok, so I bought the clipwrap software for rewrapping the footage. Now i'm wondering which Pro res 422 version I should use. I know the data rates of each, and logic says that if recording at 136mBits + on the quantum v9b hack, then I should use 422 HQ, but to be honest, I cant seem to see much difference between the 422HQ and the 422 (certainly not 1.5x size worth).
Im thinking i'll stick with just 422, but i'm thinking then is it worth recording 136, or am I better with just using quantum 100 as plain pro res 422, is capped at 100mbits.
Thoughts?
Follow up on what course I took. We bought a much faster computer with plans on creating a hackntosh (google is your friend) but ran into a roadblock with a funny European BIOS menu and that never happened.
After a ton more research we decided to ditch FCP all together and start working with VEGAS as it handles native AVCHD much better. Vegas has worked flawlessly and the learning curve was minor. There are a ton of Pro’s and con’s to FCP but for us the resources required to natively edit AVCHD was the deal breaker in addition to the increase hardware cost of a stock apple.
We do not foresee a need to switch back to FCP for the work we are doing or get an apple again for editing.
Best of luck to you if you push through getting FCP to work
