DJI Action 2 topic
    Specs:
    • 1/1.7″ CMOS sensor
    • 155-degree FOV
    • Aperture of f/2.8
    • 12MP stills
    • 4K video up to 60 fps
    • Slo-Mo 4K 120 fps
    • Rocksteady 2.0 with level horizon
    • 100 Mbps video recording bit-rate
    • $399 at https://www.dji.com/dji-action-2
  • 21 Replies sorted by
    1055 x 1055 - 77K
    2000 x 1125 - 108K
  • First leaked image of "Action 2".
    1354 x 1354 - 252K
    800 x 475 - 35K
  • October 27. Same day as GH6.
    1080 x 1350 - 634K
  • New good leak
    DJI Action 2 --- More than Action!
    DJI Action 2 isn't just ultra-versatile, it's also our most powerful action camera yet. The innovative magnetic design lets you effortlessly swap out accessories as you capture life on the go. From parkour to park walks, break the mold with DJI Action 2.
    Crafted with Precision
    1. The lightweight aluminum alloy body has a sleek minimalistic look and a smooth and solid feel.
    2. Action 2's innovative magnetic locking design allows you to interchange accessories quickly and securely.
    3. The shape and angle of the lens has been carefully considered for optimal performance and beauty.
    The Power to Wow
    Action 2 offers industry-leading performance and is packed full of intuitive features. With all this power, users can capture memorable footage from the spectacular to the everyday, even in harsh conditions.
    4K/120fps
    Record stunningly smooth footage with rich details that stands out from the rest. DJI Action 2 reaches never-before-seen heights with its capability to shoot 4K/120fps.
    155° --- Super-Wide FOV
    Enhance your perspective and gain improved depth of field with an ultra-wide 155° FOV. Action 2's custom aspheric lens sharpens edges and reduces image distortion.
    HorizonSteady
    HorizonSteady keeps your footage level, no matter how wild the action gets. From go-karting to dirt biking, DJI's latest built-in stabilization algorithm detects and corrects camera shake and rotation in real-time.
    All-Terrain, All Action
    Built tough, the Action 2 Camera Unit is drop-proof, dustproof, and waterproof at depths of up to 10 meters. [2] And with a touchscreen and lens constructed of gorilla glass, it's durable enough for any adventure
    Unleash Your Creativity
    Timelapse
    Show off your creative flair with a show-stopping timelapse. Capture the bustle of the city or storm clouds rolling in with a sped-up passage of time.
    8x Slow Motion
    A near miss, the moment of impact, or the break of a wave are all the more epic in slow-mo. With Action 2, you can even enable or disable slow motion during shooting for precise timing and more freedom.
    Digital Zoom
    Seamlessly switch from close-ups to distance shots, even as you shoot, to add greater depth to your footage.
    Made for Action, and So Much More
    Action 2's magnetic design lets users freely snap and switch between powerful modules and accessories. This fluidity of form makes it the ultimate multi-functional action camera.
    Front Touchscreen Module --- Double Down on Your Creativity
    Snap on the Front Touchscreen Module and make yourself the center of attention. Designed with vloggers in mind, the front-facing OLED touchscreen and 4-mic Matrix Stereo let you compose videos and capture crisp audio as you narrate your adventures. And when connected, Action 2's battery life is increased to a maximum of 160 minutes when filming. [3] Some things just click!
    Intelligent Audio
    • 4-mic Matrix Stereo
    • Audio Zoom
    • Directional Audio
    Power Module
    A Boost When You Need it Most Did somebody say power couple? Get more out of your Action 2 with the Power Module. When connected, Action 2 gains a microSD card slot and can film for up to 180 minutes. [3] It's even hot-swappable, so you can keep filming without missing a beat.
    What's in the box?
    • 1 x Action 2 Camera Unit
    • 1 x Power Module
    • 1 x Magnetic Lanyard
    • 1 x Magnetic Adapter Mount
    • 1 x Power Cable
    Specification
    • Dimensions: 39 x 39 x 22.3mm
    • Waterproof: 10m without case, 60m with the Waterproof Case
    • Weight: 56g
    • Touchscreen: 1.76 inches
    • Sensor: 1/1.7" CMOS
    • Lens: FOV: 155°f/2.8
    • ISO Range: Photo: 100--6400, Video: 100--6400
    • Electronic Shutter Speed: Photo: 1/8000--30s, Video: 1/8000s
    • Max Photo Res: 4000x3000
    • Digital Zoom: Photo: 4x, Video: upto 4x
    • Slow Motion Zoom: 2x
    • Photo Res: 12MP
    • Video Res: 4K
    • Operating Time: 70minutes
    • Operating Time with Power Module: 180minutes
    • Charging Time with Power Module: 90minutes
    513 x 620 - 72K
    1060 x 1413 - 99K
    1590 x 3000 - 285K
    1526 x 3000 - 226K
    3000 x 2964 - 369K
    1667 x 3000 - 298K
    Specs:
    • 155-degree FOV
    • Aperture of f/2.8
    • 12MP stills
    • Slo-Mo 4K 120 fps
    800 x 747 - 63K
  • You gotta give it to DJI for making a form factor which is totally different from the original Action.
    And making a Røde Wireless Go2 killer at the same time.
  • Let's go at it (nicely) - this DJI camera versus the GoPro Hero 10:
    The new DJI definitely has a real advantage in low light - the sensor size is larger and the pixel sizes are smaller (less pixels than the GoPro).
    The new DJI is smaller, without adding modules.
    But, there is only one mic on the camera module (no stereo?) but three on the added cost specialized "front view" module, there is no stabilization at all when shooting 4K 100 or 120 fps, "HorizonSteady" is only available when the video resolution is 1080p (16:9) or 2.7K (16:9), no replaceable battery, the max resolution is 4K, and attaching the power module you lose waterproofness.
    The Hero 10 has built-in stereo mics, there is stabilization in all shooting modes, including 4K 120p, there is horizon leveling in all modes, replaceable battery, and the max resolution is 5.3K. The latter is a big deal, given the necessary cropping of EIS that both cameras have. Cropped 4K, no...
    Am I missing some advantage of the new DJI? It is cute, it is different. It is possible the bitrates are higher in the DJI, but one cannot tell from the specs on their web site, since it does not specify the codec (it seems it will do HEVC unlike the previous model, but maybe not in all modes). Color modes?
  • DJI Mic looks better than the Action 2.
