I hacked my GH2 with Flowmotion. Should it show on the Version Disp. screen? It still shows Ver.1.1 for Body and Lens Firmware.
Thanks again.
yes. Normal GH2 has less mbits per second. This shows over 100 megabits per second on your file, the patch has been successfully installed.
my file says 115393KBPS. Does that seem right for Flowmotion?
Great. Thank you!
anything is like putin right click on the file while using windows and put MEDIAINFO and check out the bitrate and the file size, compare it to a classic file of GH2, if its heavier and has more bitrate, then the hack was succesfull.
Thank you. Not sure what you mean by "use a anything".
It doesn’t show anything. If the patch process was successfully made, you should check out your footage and use a anything to look at the bitrates, that should indicate if your hack was done right.
