150-600mm F5-6.3 DG DN OS Sports Sigma lens
  • 16 Replies sorted by
    770 x 968 - 90K
  • PR
    Capture the magic through your finder
    1. Uncompromising optical performance throughout the zoom range
    2. Fast, high-precision AF and impressive functionality
    3. Outstanding build quality optimized for ultra-telephoto photography
    Introducing the SIGMA 150-600mm F5-6.3 DG DN OS | Sports, a powerful ultra-telephoto zoom and the first ever Sports line lens for mirrorless systems. This portable and practical optic revolutionizes the way mirrorless users capture wildlife, motorsport and other fast-action subjects.Introducing the SIGMA 150-600mm F5-6.3 DG DN OS | Sports, a powerful ultra-telephoto zoom and the first ever Sports line lens for mirrorless systems. This portable and practical optic revolutionizes the way mirrorless users capture wildlife, motorsport and other fast-action subjects.
    The 150--600mm F5-6.3 DG DN OS | Sports is SIGMA Sports line's first ultra-telephoto zoom lens, designed from the ground up specifically for full-frame mirrorless cameras. It offers outstanding levels of performance, functionality, and build quality required for ultra-telephoto shooting in the most demanding situations.Image quality is exceptional, with ultra-high-performance glass capable of delivering ultra-sharp results even on the highest resolution cameras. The lens displays beautiful bokeh throughout its zoom range, and optical aberrations are kept well under control. It can be used with SIGMA's 1.4× and 2× L-Mount teleconverters, with AF effective up to 1200mm.
    Fast and accurate autofocus owing to an AF unit equipped with a high-precision magnetic sensor, combined with an OS (Optical Stabilizer) function effective to approximately 4 stops* of image stabilization makes this a highly responsive lens that can handle even the most challenging subjects. It has a Dual Action Zoom system that includes straight and ring zoom, a dust and splash resistant structure, and customizable switches helping photographers and filmmakers adapt quickly and easily to virtually any shooting environment.
    Capture the long-reach images you have always wanted with an ultra-telephoto lens---that's the visual experience you will enjoy with the 150-600mm F5-6.3 DG DN OS | Sports, the first ultra-telephoto lens for mirrorless systems from SIGMA Sports line.* Based on CIPA guidelines (measured in 600mm with a 35mm full-size image sensor)
    Key features
    The SIGMA 150-600mm F5-6.3 DG DN OS | Sports offers outstanding optical performance throughout its zoom range and at all apertures, yielding professional quality results.
    Based on the latest optical design technology, its lens construction of 25 elements in 15 groups includes a range of special types of high-performance glass that ensures thorough control of different types of aberrations. This helps give images the resolution and clearest detail---not only at the tele end around 600mm, which is critical for an ultra-telephoto zoom, but also throughout its entire zoom range---with no compromise. The lens was designed with image quality in the out-of-focus areas in mind as well, with attractive compression and beautiful bokeh for creating eye-catching images that can only be achieved with a long focal length.
    Through improvements to the optical and mechanical designs as well as extensive simulated testing, the lens has achieved high resistance to ghosting and flare. This helps ensure sharp and high-contrast images even in strong sunlight or in backlit conditions.
    At the wide end of 150mm, the lens has an impressive minimum focusing distance of 58 cm. On the L-Mount, the use of two dedicated teleconverters will allow you to shoot with AF up to 1200mm. With these features, this new ultra-telephoto lens is the perfect tool for tackling a broad range of shooting situations, giving you a greater freedom in your choice of composition.
    The 150-600mm F5-6.3 DG DN OS | Sports comes with the pro-level functionality that defines the SIGMA Sports line lens, which is designed for capturing fast-action subjects.
    With an AF actuator controlled by a stepping motor, the lens combines fast and quiet autofocus with excellent tracking of moving objects. Furthermore, a high-precision magnetic sensor enables highly accurate positioning for fast and high-precision AF. This is particularly impressive on an ultra-telephoto lens where the focus lens has to move a significant distance.
    The OS function delivers effective image stabilization that offers an advantage of approximately 4 stops*, which is ideal for hand-held shooting at slower shutter speeds. It is possible to change the OS settings using the OS switch and Custom Mode switch to best suit the shooting situation. The lens has a Focus Limiter switch offering three-zone AF modification, which helps to speed up AF performance, and on the L-Mount it is possible to set a custom focusing limit via the SIGMA USB DOCK. The lens also has three AFL buttons to which you can assign various functions on the camera side depending on the model of camera used. This ensures that key settings are able to be customized to suit your shooting style and be accessed easily so that you can adapt quickly to changing conditions. With the fast and high-precision AF, 4 stops* image stabilization, and a wide range of customizable functionality that comes with the SIGMA 150-600mm F5-6.3 DG DN OS | Sports, the creative possibilities are limitless.
    The 150-600mm F5-6.3 DG DN OS | Sports combines the build quality that upholds the SIGMA Sports line standards with excellent operability, taking into account different shooting environments and modes of operation expected with an ultra-telephoto lens.
    A dust and splash resistant structure that stops water drops or dust from getting into the lens, combined with a water and oil repellent coating applied to the front element, gives you a peace of mind even in a harsh shooting environment.
    The lens features a Dual Action Zoom, which supports both straight zoom and ring zoom, allowing you to change the angle of view in a quick and intuitive way. In addition, there is also a newly incorporated Zoom Torque switch, with which you can change the resistance of the zoom ring and lock it at the wide end, ensuring ease of zoom operation as well as elimination of zoom creep.
    On the lens body there is a magnesium tripod socket attachable to an Arca Swiss type clamp. The foot is removable and may be replaced with an optional lens foot (replaceable lens foot type) or mounted on a monopod.
    The lens body uses parts made of aluminum and TSC (Thermally Stable Composite), where they are most suitable. TSC is a type of polycarbonate with a thermal expansion rate similar to that of aluminum, ensuring the lens behaves consistently at different temperatures. By taking advantage of its design intended exclusively for mirrorless camera systems, the lens is both robust---an attribute essential for the Sports line of lensesーand compact and lightweight. Compared to the SIGMA 150-600mm F5-6.3 DG OS HSM | Sports, which is also a Sports line lens but designed for SLR cameras, the new lens is lighter by 760g and shorter by 26.6mm.
    Additional features
    • Lens construction: 25 elements in 15 groups, with 4 FLD and 2 SLD elements
    • OS function
    • Internal focusing
    • Compatible with high-speed autofocus
    • Stepping motor
    • Compatible with lens aberration correction
    • Support DMF and AF+MF
    • Super Multi-Layer Coating
    • Water and oil repellent coating (front element)
    • Focus Mode switch
    • Focus Limiter switch
    • OS switch
    • Custom Mode switch
    • AFL button (3 buttons)
    • Zoom Torque switch
    • Tripod Socket (TS-121) fixed
    • Cover Hood (LH1034-01)
    • Dust and splash resistant structure
    • Compatible with SIGMA TELE CONVERTER TC-1411 / TC-2011 (sold separately / for L-Mount only)
    • Compatible with SIGMA USB DOCK UD-11 (sold separately / for L-Mount only)Compatible with SIGMA TRIPOD SOCKET TS-81 (Replaceable lens foot type / sold separately)
    • Designed to minimize flare and ghosting
    • Every single lens undergoes SIGMA's proprietary MTF measuring system9-blade rounded diaphragm
    • High-precision, durable brass bayonet mount
    • "Made in Japan" craftsmanship
    To learn more about SIGMA's craftsmanship, please visit SIGMA website at https://www.sigma-global.com/en/about/craftsmanship/
    794 x 500 - 117K
    638 x 499 - 43K
