16-50mm F2.8 HD PENTAX-DA* ED PLM AW 2021 lens
    Some specs
    • 16 elements in 10 groups, ED + anomalous glass + aspherical elements
    • HD coating
    • F22 min aperture
    • 9 diaphragm blades
    • Stepper AF motor
    • APS-C coverage
    • Relatively quiet operation (for photo guys)
    • Weather sealed
    • 77mm filters
    • 84mm x 117mm
    • 712 g
    • Available in August of 2021 for $1,400
  • 3 Replies sorted by
  • Ricoh Imaging Americas Corporation today announced the HD PENTAX-DA★ 16-50mm F2.8ED PLM AW lens, the latest addition to the new generation PENTAX Star (★) lens series. Designed for use with PENTAX K-mount digital SLR cameras, Star-series lenses boast the highest imaging performance of all PENTAX lens lineups. This large-aperture standard zoom lens features an open aperture of F2.8 over the entire zoom range to deliver exceptional optical performance and is an ideal regular-use lens for the recently announced PENTAX K-3 Mark III.
    The HD PENTAX-DA★ 16-50mm F2.8ED PLM AW lens incorporates a newly designed optical system and—for the first time in a large-aperture PENTAX lens—an advanced pulse motor (PLM) to assure smooth, high-speed, high-precision autofocus (AF) operation with minimized noise. The lens has been fine-tuned for greater operability in manual-focus operation and includes a quick-shift focus system to provide an instant shift from AF to manual. It provides a minimum focusing distance of just under 12 inches and a maximum magnification of 0.24x. This new standard zoom lens allows users to fully enjoy the process of photography according to their own preferences and can be used in a variety of applications including landscape, snapshots and portraits.
    The HD PENTAX-DA★ 16-50mm F2.8ED PLM AW lens also features an electromagnetic diaphragm control mechanism to assure high precision exposure control and smooth focus tracking when used in combination with compatible digital SLR cameras. The mechanism also enables the capture of video clips using automatic exposure control, even when there are considerable differences in brightness when shooting.
    The lens has been designed to provide sharp, clear images free of flare and ghost images, even under demanding conditions like backlight. It features a nine-blade circular diaphragm to produce a natural, beautiful bokeh (defocus) effect even at open aperture. It has been treated with the PENTAX-original HD coating, which assures much higher light transmittance than conventional multi-layer coatings.
    The new AW (All Weather) lens features dustproof, weather-resistant construction to prevent the intrusion of water and dust into the lens barrel. When paired with a dustproof, weather- resistant PENTAX digital SLR camera body, it assures a durable, reliable digital imaging system that performs superbly in demanding shooting settings — even in rain or mist, or at locations prone to water splashes or spray.
    Pricing and Availability
    The HD PENTAX-DA★ 16-50mm F2.8ED PLM AW lens will be available August 2021 at www.us.ricoh-imaging.com as well as at Ricoh Imaging-authorized retail outlets for a manufacturer’s suggested retail price of $1,399.95.
    Main Features of the new HD PENTAX-DA★ 16-50mm F2.8ED PLM AW
    New-generation Star-series lens, designed for optimal image quality
    The latest addition to the new-generation Star-series lenses — which provides the greatly improved resolving power that will accommodate the super-high-performance digital cameras of the future — this standard zoom lens compensates various aberrations to a minimum and delivers sharp, clear images, not only in the middle of the image field but at the edges. Incorporating one ED (Extra-low Dispersion) glass optical element, one anomalous glass optical element and two ED (Extra-low Dispersion) aspherical glass optical elements, it effectively reduces chromatic aberration to a minimum over the entire zoom range. Coupled with high-grade, multi-layer HD Coating,* which reduces the average reflectance in the visible ray spectrum to less than 50% that of conventional multi-layer coatings, it effectively minimizes flare and ghost images even in demanding lighting conditions such as backlighting.
    This standard zoom lens delivers exceptionally high resolving power and outstanding contrast even at open aperture, while capturing beautiful images with a smooth transition of the bokeh (defocus) effect and a true-to-life depth of field. Since its maximum aperture is fixed at F2.8 over the entire focal-length range from 16 to 50 millimeters (equivalent to 24.5mm to 76.5mm in 35mm format), this large-aperture zoom lens makes it an ideal regular-use lens for the PENTAX K-3 Mark III.
    High-speed AF system with a minimum focusing distance of 0.3 meters
    This zoom lens incorporates a newly designed optical system which features a lighter, more compact focus-lens group. By driving this focus-lens group with an advanced PLM (Pulse Motor), it assures smooth, high-speed autofocus operation with minimized operational noise. Thanks to the redesigned focus mechanism, it provides the minimum focusing distance of just 0.3 meters, and the maximum magnification of 0.24 times, making this a versatile, regular-use lens for capturing all types of subjects — from everyday snapshots to close-ups and landscapes.
    Electromagnetic diaphragm mechanism for high-precision diaphragm control
    This zoom lens features an electromagnetic diaphragm control mechanism* to assure high- precision exposure control when used in combination with compatible digital SLR cameras. It also lets the user capture video clips using automatic exposure control, even when there are considerable differences in brightness during the video shooting. When mounted on a PENTAX K-3 Mark III, PENTAX KP or PENTAX K-70 camera body, the PLM (Pulse Motor) assures smooth focus tracking operation and flawless exposure control, while considerably reducing annoying noise generated by focus and diaphragm control operations during video shooting. It assures smooth, worry-free video shooting in locations prone to considerable brightness changes — such as a stage with rapidly changing lighting conditions, or a forest with filtering sunrays — or with active, fast-moving subjects such as athletes or animals.
    The lens features the KAF4 mount and is compatible with electromagnetic diaphragm control. Electromagnetic diaphragm control is available in combination with PENTAX K-3 Mark III, PENTAX K-3 II, PENTAX K-3, PENTAX KP, PENTAX K-70, PENTAX K-50, PENTAX K-S2, PENTAX K-S1, PENTAX K-1 Mark II or PENTAX K-1 camera bodies. We advise that users upgrade the camera’s firmware to the latest version to properly use electromagnetic diaphragm control. When mounted on a PENTAX K-1 Mark II or PENTAX K-1 camera body, images can only be captured in Crop mode because the lens image circle is exclusively designed for the APS-C format.
    Dustproof, weather-resistant construction
    Developed as an AW (All Weather) model, this zoom lens features a dustproof, weather- resistant construction to prevent the intrusion of water and dust particles into the lens interior. By pairing it with a PENTAX dustproof, weather-resistant digital SLR camera body, the user can create a highly durable, reliable digital imaging system that performs superbly even in the most demanding shooting conditions — in rain or mist, or at locations prone to splashing water.
    792 x 529 - 46K
