Today I've killed my E1. To continue my hacking work I need another E1.
If someone wants to sell Z-CAM E1, I can buy it.
Already in process. Camera still works from battery, but charging does not work. LCD backlight does not work too.
But anyway I need another E1 (clean) that I'll use for testing final hack versions.
This must be even more easy (but can be worse).
Check notebook or smartphone service guys, but good ones (as they need understand principles).
Usually it will be DC-DC stuff that is blown or some other stuff near input.
But if design had been lazy or wrong it can be main stuff that got full DC on their voltage rail.
Just messed with voltages - powered it with 12V instead of 5V by mistake.
How you killed it?
As far as I remember it has external NAND chip, so refreshing is possible.
