Sony Alpha 1, 8K top model with record margins
  • 87 Replies sorted by
  • 1.6 lbs hurrrr hurrrrr
    Also no true 24p just 23.976? Maybe a firmware thing.
  • the limit is due to "overheating" but thats something we have to see! maybe is a marketing low kick to canon 30 minute limit
  • Is there a single adapter that will allow me to use my Minolta glass on this cam?
    Nevermind I see metabones will take all my cash.
  • @paglez where do you see 30 minute limit?
    "No recording time limit allows for unlimited clip lengths and the camera's physical design features an improved heat-dissipating structure to promote longer possible recording times; longer than 30 minutes for 8K 30p or 4K 60p videos, or recordings done at 10-bit 4:2:0." (from BHPhoto...)
  • $6500
    Hmmmm....
  • 8k mode, 30 min limit.
  • "4k 4:2:2 10 bit up to 120fps (max 600mps)
    FHD 4:2:2 10 bit up to 240fps (max 200mps)
    no recording limit"
    Exactly the same as the a7s iii. So, if you understand why 8K is useless and are interested in video, this new camera adds little in video capability to the a7s iii, and will have much worse low-light performance (much smaller pixels).
  • @jazzroy
    It's funny course I very much like the colors, tones and details. Maybe our eyes have a different perception. :)
  • Long time I don't see such awful skin tones.
    the dancer's face switches from yellow to pink/red never nailing a proper natural skin colour.
    Dynamic range is quite poor too, with black dark areas in exteriors.
    Maybe it's just bad post production..
    No idea who can get excited by this demo.
  • 8k 4:2:0 10 bit up to 30fps (max 400mps)
    no recording limit
    no wallet limit (new alfa can make holes on wallet beware)
  • This is a killer one! Wow.
    grate DR grate resolution. They sure know how to make sensors.
    MOVIE RECORDING SYSTEM (XAVC HS 8K)
    7680 x 4320 (4:2:0, 10bit, NTSC) (Approx.): 30p (400 Mbps / 200 Mbps), 24p (400 Mbps / 200 Mbps), 7680 x 4320 (4:2:0, 10bit, PAL) (Approx.): 25p (400 Mbps / 200 Mbps)
    MOVIE RECORDING SYSTEM (XAVC HS 4K)
    3840 x 2160 (4:2:0, 10 bit, NTSC) (Approx.): 120p (200 Mbps), 60p (150 Mbps / 75 Mbps / 45 Mbps), 24p (100 Mbps / 50 Mbps / 30 Mbps); 3840 x 2160 (4:2:0, 10 bit, PAL) (Approx.): 100p (200 Mbps), 50p (150 Mbps / 75 Mbps / 45 Mbps); 3840 x 2160 (4:2:2, 10 bit, NTSC) (Approx.): 120p (280 Mbps), 60p (200 Mbps / 100 Mbps), 24p (100 Mbps / 50 Mbps); 3840 x 2160 (4:2:2, 10 bit, PAL) (Approx.): 100p (280 Mbps), 50p (200 Mbps / 100 Mbps)
    MOVIE RECORDING SYSTEM (XAVC S 4K)
    3840 x 2160 (4:2:0, 8 bit, NTSC) (Approx.): 120p (200 Mbps), 60p (150 Mbps), 30p (100 Mbps / 60 Mbps), 24p (100 Mbps / 60 Mbps); 3840 x 2160 (4:2:0, 8 bit, PAL) (Approx.): 100p (200 Mbps), 50p (150 Mbps), 25p (100 Mbps / 60 Mbps); 3840 x 2160 (4:2:2, 10 bit, NTSC) (Approx.): 120p (280 Mbps), 60p (200 Mbps), 30p (140 Mbps), 24p (100 Mbps); 3840 x 2160 (4:2:2, 10 bit, PAL) (Approx.): 100p (280 Mbps), 50p (200 Mbps), 25p (140 Mbps)
    MOVIE RECORDING SYSTEM (XAVC S HD)
    1920 x 1080 (4:2:0, 8 bit, NTSC) (Approx.): 120p (100 Mbps / 60 Mbps), 60p (50 Mbps / 25 Mbps), 30p (50 Mbps / 16 Mbps), 24p (50 Mbps); 1920 x 1080 (4:2:0, 8 bit, PAL) (Approx.): 100p (100 Mbps / 60 Mbps), 50p (50 Mbps / 25 Mbps), 25p (50 Mbps / 16 Mbps); 1920 x 1080 (4:2:2, 10 bit, NTSC) (Approx.): 60p (50 Mbps), 30p (50 Mbps), 24p (50 Mbps); 1920 x 1080 (4:2:2, 10 bit, PAL) (Approx.): 50p (50 Mbps), 25p (50 Mbps)
    MOVIE RECORDING SYSTEM (XAVC S-I 4K)
    3840 x 2160 (4:2:2, 10 bit, NTSC) (Approx.): 60p (600 Mbps), 30p (300 Mbps), 24p (240 Mbps); 3840 x 2160 (4:2:2, 10 bit, PAL) (Approx.): 50p (500 Mbps), 25p (250 Mbps)
    MOVIE RECORDING SYSTEM (XAVC S-I HD)
    1920 x 1080 (4:2:2, 10 bit, NTSC) (Approx.): 60p (222 Mbps), 30p (111 Mbps), 24p (89 Mbps); 1920 x 1080 (4:2:2, 10 bit, PAL) (Approx.): 50p (185 Mbps), 25p (93 Mbps)
    Slow & quick motion (shooting frame rate)
    NTSC mode: 1fps, 2fps, 4fps, 8fps, 15fps, 30fps, 60fps, 120fps, 240fps, PAL mode: 1fps, 2fps, 3fps, 6fps, 12fps, 25fps, 50fps, 100fps, 200fps
    Movie Functions
    Audio Level Display, Audio Rec Level, PAL/NTSC Selector, Proxy Recording (1280 x 720 [6 Mbps], 1920 x 1080 [9 Mbps], 1920 x 1080 [16 Mbps]), TC/UB, Auto Slow Shutter, Gamma Disp. Assist, RAW Output(HDMI)
    Picture Profile
    Yes (Off / PP1-PP11) Parameters: Black level, Gamma (Movie, Still, S-Cinetone, Cine1-4, ITU709, ITU709 (800%), S-Log2, S-Log3, HLG, HLG1-3), Black Gamma, Knee, Color Mode, Saturation, Color Phase, Color Depth, Detail, Copy, Reset
