AMD Zen 3 aka Ryzen 5xxx CPUs
  • First unofficial 2020 roadmap surfaced
    Some very early leaks and predictions:
    • 7nm+ process, mostly to make products cheaper by using EUV on some parts
    • around +100Mhz frequency rise on average, +200Mhz stock for top models
    • 1-3% IPC progress
    • DDR4 memory controller must stay same as in Zen 2
    • Possible DDR5 controller for premium x670 boards
    • 8 core price is expected to drop to $199
    • 16 core to $499
  • 65 Replies sorted by
  • CPUs started to become cheaper
    748 x 112 - 24K
  • New huge issues
    PowerGPU, which builds and sells PCs, says that it records a very impressive number of failures or defects in the latest AMD CPUs.
    More precisely, the source data is as follows:
    • Ryzen 9 5950X - 8 dead CPUs per 50 units (16%)
    • Ryzen 9 5900X - 4 "dead" CPUs at 50 units (8%)
    • Ryzen 7 5800X - 4 dead CPUs per 100 units (4%)
    • Ryzen 5 5600X - 3 "dead" CPUs at 120 units (2.5%)
    And it is not even returns that can happen within 1-2 year, it is dead CPUs.
  • Cheaper CPUs coming
    752 x 522 - 75K
  • New PBO coming
    800 x 427 - 57K
    800 x 430 - 50K
    800 x 440 - 48K
  • Chiplet
    IO Die (same as Zen 2)
    800 x 520 - 151K
    746 x 559 - 61K
  • Chiplets difference
    746 x 750 - 66K
    745 x 716 - 80K
    674 x 300 - 34K
    667 x 300 - 35K
    662 x 276 - 31K
    669 x 275 - 35K
    800 x 409 - 66K
    800 x 421 - 62K
    800 x 406 - 50K
    800 x 365 - 43K
    800 x 385 - 49K
    800 x 418 - 55K
    751 x 511 - 41K
    800 x 446 - 30K
    616 x 335 - 21K
  • Single thread performance
    744 x 334 - 50K
    562 x 855 - 71K
    BIOSTAR also will do standard things and add support to some older MBs, but not 3xx series.
    745 x 370 - 38K
  • Some new benchmarks
    800 x 459 - 36K
    800 x 457 - 34K
  • MSI on motherboards support
    • X370, B350 and A320 board won't get any support
    • B450 and X470 boards will get some support
    Main reason that AMD provides fully solid and encrypted AGESA or AMD Generic Encapsulated System Architecture BIOS part. Such way they can prevent old chipset from getting modern CPU support.
    Exactly same way they disabled PCIe 4.0 support on older chipsets (actually main M.2 and PCIe x16) spots onall B450 and B350 motherbaords can work in PCIe 4.0.
    Such way corporation is making tens of billions of damages and huge ecology impact by forcing unnecessary updates, and all for 3-4 main investors and less than 100 of top managers to get their big cut. This guys are open criminals.
  • On memory
    800 x 405 - 48K
  • ASUS will provide updated BIOS' for the X470 and B450 chipsets based on AMD's current release schedule of new AGESA code in January 2021. This original report was based on incorrect information.
  • On BIOS updates
    Taiwan manufacturers current plans
    • Most X570 and B550 boards will get updates
    • Most X470 board won't get updates
    • Almost all B450 board won't get updates
    • Almost none or totally none of X350 and B350 (totally marketing decision)
    800 x 438 - 61K
  • AMD IO die part
    It is exactly same as in Zen 2, cheap as shit, 12nm thing.
    x570 chipset is also exactly same die :-)
    AMD had much better memory controller in mobile and hybrid latest CPUs, but did not updated IO chiplet, as this required changing masks (aka few less Ferrari cars for AMD top management). All extra profits will be guided to more buybacks and top managers bonuses, none into development.
  • UK prices
    • Ryzen 9 5950X - 750 GBP
    • Ryzen 9 5900X - 530 GBP
    • Ryzen 7 5800X - 430 GBP
    • Ryzen 5 5600X - 290 GBP
    EU prices
    • Ryzen 9 5950X - 830-850 EUR
    • Ryzen 9 5900X - 570-580 EUR
    • Ryzen 7 5800X - 470-480 EUR
    • Ryzen 5 5600X - 313-320 EUR
    Note that AMD also excluded coolers from all but cheapest 6 core models, so profits (including saving on cooler and price rise) are around $100 bigger for most models now.
  • Single core results
    340 x 617 - 43K
  • Some slides
    800 x 455 - 60K
    800 x 465 - 42K
    800 x 462 - 53K
