Detailed tech view
NVIDIA has revised the plans for the upcoming RTX 30 series ‘refresh’. If you were planning (or trying) to buy a high-end GPU, then you should definitely wait for December. Our sources are confident that NVIDIA will launch two SKUs: 3080 20GB and 3070 16GB in that month.
Fully correct. Do not buy modern GPU card with less than 16GB, but 20GB or 24GB are better.
Proshop orders status
Situation with Samsung manufacturing is horrible.
NVIDIA GeForce RTX 3090 & RTX 3080 Shortages To Last Until 2021 As Demand Exceeds Expectations, States CEO Jensen Huang
Demand has nothing to do with it, as main issue is constant problems with Samsung 8nm manufacturing that last more than a year already and have no solution in sign.
RTX A6000 & A40 Video Cards
https://www.anandtech.com/show/16137/nvidia-announces-ampere-rtx-a6000-a40-cards-for-pro-viz
More 3070 chip photos
RTX 3070 performance
On capacitors
EK Water Blocks made stuff for RTX 3080 and RTX 3090
Common idea to use transparent acrylic parts is stupid die too big difference in temperature expansion between copper part and this transparent cover. Add to this single sealing - and this thing will certainly leak with time.
RTX 3080 crashes seems to be hardware related
Rumor is that next update will have consumption in the 450-600W range and will have water cooling installed, no more air cooling.
RX 3090 board
Very big thermal density, issue with memory cooling is worse than in RX 3080 already bad case.
Rear memory cooling is terrible.
ASUS RTX 3080 ROG STRIX Board - huge waste of resources
