Hi, Question about SD CARD operation. There are 2 SanDisk Extreme PRO 95Mb/s cards. One is 64GB and the other is 32GB. On GH2 with a stream of 157 Mbit, 64 works from and to, and 32 stops at 3-4 minutes just before closing the file. Blackmagic Speed Test the speed of reading and writing on both maps shows the same (which is important). Any ideas?
Moon t7 was never stable enough.
Ok. But at the same 64gb without trouble. SD is the same except for the volume. And this is not a rec error. Rec stop after 4gb file.
