85mm F1.8 Yongnuo lens
  • 5 Replies sorted by
    Small size, lightweight design
    The maximum diameter and length of the lens are about 67×88mm, net weight is only about 346g. The lightweight design is good for long-term handheld shooting and video recording.
    Equipped with Fn function key
    Equipped with Fn custom function buttons, proper allocation of buttons allow you to quickly call up a function menu or perform a shortcut operation, improving the efficiency of creation.
    Equipped with AF/MF focus mode switch
    Using the AF/MF focus mode switch you can quickly switch the focus mode.
    Equipped with quiet AF stepping motor
    Compared with traditional DC motors, digitally controlled stepping motors ( DSM ) have quick start-stop response, higher focusing accuracy, and quieter focusing action, which is suitable for photo shooting and video recording.
    F 1.8 large aperture
    Flexible use of F1.8 large aperture, makes it easy to obtain soft blur effect, work nice with low sensitivity and higher shutter to shoot in low light environment.
    9 optical lenses in 8 groups, nano multilayer coating
    It adopts 8 groups and 9 -element optical structure design, and the lens uses nano-multilayer coating process , which effectively improves the light transmittance and suppresses the ghost image and glare of backlight .
    Low dispersion lens
    Lens has low-dispersion glass lens, so aberrations are suppressed to better dispersion problems.
    7 circular aperture blades
    The 7- piece circular aperture blade design can produce nice smooth circular diffuse spots, and a proper reduction of the aperture can also produce a 14- star effect.
    USB firmware upgrade
    Equipped with a USB Type-C interface, you can download the latest firmware to upgrade the lens to keep the lens at its best performance.
    Metal bayonet, gold-plated contacts
    The use of high-precision metal bayonet and gold-plated contacts effectively improves signal conductivity and corrosion resistance, and is durable. At the same time, it allows the camera and lens to maintain reliable communication, and realizes functions such as autofocus, aperture control, and EXIF information transmission.
    633 x 629 - 49K
  • FE Lens
    691 x 485 - 43K
    576 x 864 - 75K
