ASUS totally fucked the Nvidia idea with cooling improvement by mostly blocking third fan
Broadcast app that will be abandoned in 1-2 years completely
RTX 3080 GPU will sell for $699, the same as the current 2080, while the mid-range RTX 2070 will go for $499. NVIDIA says the RTX 3080 is twice as fast as the 2080, while the 3070 is even faster than the RTX 2080 Ti.
Nvidia specially lowered prices and moved RTX 3090 out of this event focus to avoid negative backslash.
The RTX 3080 willl feature 39 shader teraflops instead of just 11, and 58 RT TFLOPs, compared to 34. But Ampere's biggest leap is in its AI Tensor Cores, which clock in 238 tensor TFLOPs instead of just 89.
Nice marketing stunt to replace performance of FP32 into FP16, but this strange terms also need independent explanation.
Same strange
NVIDIA says the RTX 3090 can reach 36 shader teraflops, compared to the RTX 2080 Ti’s 13.4 TFLOPs.
RTX 3090 PCB
Some little fake charts, note that it is in DLSS mode and also using RTX and all on ultra settings.
Rumors are that as you drop settings and use native resolutions difference drops to 15-20%
Can be even for 4-5 years. Note that RAM is important, as it makes sense to orient on GPU that will work with 8K properly.
And if you want cheap two used 1080 TI's are usually better 9and cheaper) in Resolve as I remember.
So, do I get this right: 2080 ti (possibly in SLI) will stay the best affordable NVIDIA card for quite a while?
One more info on prices
Zotac cards list and some photos leaked
Present rumors
Huge 3 slots RX 3090 card
Idea of new design is to maximally increase fans diameter and depth.
Rumored prices
GeForce RTX 3090 cards prices will be from $1400 for cheapest and worst card to $2000 or even $2100 for top fo the line 3 fans versions with best cooling. Many cards can be with water cooling system.
NVIDIA will run a digital version of its GTC conference from October 5th-9th. There’ll be a keynote from CEO and founder Jensen Huang on the first day of the event at 9AM ET.
RTX 3080 leaks
Card will have
Well, if you need it only for video and alike - simpler to get used 1080 Ti or 2080 Super.
