Sony SpectraLayers, now Steinberg SpectraLayers
  • 31 Replies sorted by
  • They need to fix the interface. JKL or one-frame arrow controls would be a big help. The waveform display is crude compared to Izotope. SP is more powerful than Izotope, but a pain to use.
  • Cleaning Dialogue in Spectralayers Pro 4
  • MAGIX SpectraLayers Pro 5.0
    • A visual Spectrogram for unrivalled sound design, editing and restoration
    • Make precise edits and create incredible audio in real time
    • NEW! High definition Spectrogram for pin-sharp visual detail
    • NEW! Redesigned GUI for a smooth and fast workflow
    • NEW! Professional tools for repairing and restoring audio
    • NEW! Powerful algorithms for high-precision visual editing
    https://www.magix.com/int/music/spectralayers/
    800 x 433 - 73K
  • Owner is changed again
    Since Steinberg SpectraLayers Pro 6 it is owned by Steinberg
    https://new.steinberg.net/spectralayers/
  • SpectraLayers Elements 6
    They want to copy iZotope approach :-)
    • Surgical and intuitive spectral editing with 16 real-time tools
    • Advanced Selection Engine
    • Selection-based effects
    • The only visual transformation system for sound
    • Tracks, Regions and Clips separated as Layers
    • ARA 2 and AAX compatibility
    • Integration of other audio editors, such as WaveLab or iZotope RX
    • 2D and 3D visualization of the Spectrogram
    • Native restoration effects and spectral noise reduction
    • $79
  • Steinberg Spectralayers Pro 7
    AI
    Just as audio engineers focus on separating increasingly fine details in sound, the new AI in SpectraLayers Pro 7 uses algorithms to learn from the data flowing through its built-in neural network. In the same way that these algorithms can now accurately determine how to apply color to a black and white photograph, the AI in SpectraLayers Pro can sense discrete events in a sound field and isolate them on independent, colorful layers for processing. AI is changing faster than its history can be written — be at the leading edge with SpectraLayers Pro 7.
    Unmix - Tracks to stems
    This AI-assisted process in SpectraLayers Pro scans the finished file of a song, allowing you to “unmix” it and extract the different instruments to separate layers, with default settings for vocals, piano, bass, drums, and more. (SpectraLayers Elements allows extraction of vocals only.)
    Pattern finder
    Significant advances in pattern recognition are a hallmark of today’s rapidly evolving AI technology. SpectraLayers Pro 7 allows you to select a target sound and then trigger a search to automatically locate and select every other similar sound in the spectrum.
    Voice Denoiser
    Perfect for cleaning up location interview recordings, the Voice Denoiser algorithm is trained to recognize and isolate the human voice. You can automatically attenuate everything but the voice for maximum intelligibility.
    De-esser
    Spectral de-essing is the most precise and least invasive way to tame and shape vocal sibilants. Manual de-essing in SpectraLayers Pro has always been quick and easy. Now, the new automatic de-essing feature makes it even easier. Manual or automatic — either approach is far more accurate than typical waveform-based plug-in processing
    Hum reduction
    This automatic process detects and eliminates unwanted hum, as well as higher harmonics generated by the fundamental tone. Hum harmonics can be independently attenuated to the level you choose.
    Clip repair
    Clipped peaks come in many shapes and sizes. The AI in SpectraLayers Pro 7 has seen and evaluated 32,000 of them, so it knows exactly what to look for and how to automatically apply the best repair.
    Click repair
    Automatically detect and repair clicks, crackles and pops. Invert the process to audition problem sounds in isolation, then execute the repair after you’ve dialed in the fix you need.
    Improved healing
    Better interpolation and faster performance, now assisted by AI, looks more closely at noise, tones and transients, making this easy repair process more versatile and precise than ever.
    https://new.steinberg.net/spectralayers/new-features/
    It is clearly open attack on iZotope RX, and they could match it in next version. Price is already very friendly.
    800 x 206 - 25K
