Canon EOS R6 - Nice attempt, but no
    Rumored specs
    • 20mp full-frame CMOS sensor
    • Oversampled 5K Video
    • Video modes
      • 4K 60p, 50p, 30p, 25p, 24p
      • 1080 120p, 100p, 60p, 50p, 30p, 25p, 24p
    • Canon Log
    • 10-bit
    • No RAW video mode
    • Zebras
    • Autofocus fully match AF on EOS R5
    • Head detection AF (we are going from face detection to head detection, as some people do not have faces)
    • Animal detection AF
    • IBIS, 5 stops, up to 7-8 stops if paired with in-lens stabilization
    • 12fps mechanical, 20fps electronic
    • Built-in 5GHz WiFi
    • Bluetooth 4.2 (due to very old LSI used)
    • Same 5 million dot EVF as EOS R5
    • Dual SD UHS-II card slots
    • Flippable LCD
    • Larger capacity battery (LP-E6NH)
    • Cheap build quality
    • $2499 price, 2600 EUR price
    • Announcement 9th July 2020
    • Launching in October 2020
  • 57 Replies sorted by
    • R6 does not have magnesium alloy body
    • R6 has a top-down LCD
    • R6 has multiple scroll wheels
    • R6 has a more rounded shape than existing R models
  • Additions
    • 1080p 120fps video mode
    • Dual card slots
    • Much worse EVF compared to R5 and even current Sony cameras
    • Low build quality, saving on most things
    • No top screen
  • According to Canon Rumors multiple sources are saying that Canon has been forced to delay the announcement of the EOS R6 until July, pushing shipping for the camera until Q3 of 2020.
    Nice.
  • Seems to be registered in Asia
    660 x 531 - 59K
  • Canon EOS R6 and Canon EOS R5 announcement is now rumored to happen on July 2, 2020.
  • Options
    • Canon EOS R6 body
    • Canon EOS R6 kit with RF 24-105mm USM lens
    • Canon EOS R6 kit with RF 24-105mm STM lens
  • More rumored specs
    • Canon Log
    • 10-bit
    • Zebras
    • No RAW video mode
    • No top-down screen
    • Bluetooth 4.2
    • LP-E6NH Battery
    • Announcement July 9, 2020
    • US$2,500 price (around 2999 EUR)
  • More leaked specs
    • FF 20.1mp CMOS Sensor, has Dual Pixel CMOS AF
      • has antialiasing filter
    • DIGIC X LSI
    • OLED EVF, cheap one
      • 0.76 magnification
    • 3" LCD Monitor, not bright, only 1.62 million dots
    • Very limited Wi-Fi - IEEE 802.11b/g/n, lacks 5Ghz support in 2020!
    • Two SD card slots, UHS-II compatible
    • 138 x 97.5 x 88.4mm
    • 680g (including battery, SD memory card; without body cap) Approx. 598g (body only; without battery, card or body cap)
  • US prices
    • Canon EOS R6 - $2499
    • Canon EOS R6 w/24-105mm IS STM - $2899
    • Canon EOS R6 w/24-105mm f/4L IS USM - $3599
  • Canon EOS R6 Specifications:
    Compatible Lenses
    Canon RF lens group (excluding EF, EF-S and EF-M lenses)
    When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) Lens Mount
    Processor
    DIGIC X
    Sensor & Image Type
    CMOS sensor (compatible with Dual Pixel CMOS AF) Effective Pixels
    Approx. 20.1 megapixels Screen Size
    Approx. 36.0 x 24.0 mm Pixel Unit
    Approx. 6.56 micro m square Total Pixels
    Approx. 21.4 megapixels Aspect Ratio
    3:2 (Horizontal: Vertical) Color Filter System
    RGB primary color filters Low Pass Filter. Installed in front of the image sensor, non-detachable Recording Format
    Compliant to Design rule for Camera File system 2.0 and Exif 2.31 Image Format
    JPEG, HEIF, RAW / C-RAW (CR3), C-RAW (Canon original) ; Movies: ALL-I (Time-lapse video only), IPB, MP4
    Viewfinder Type
    OLED color electronic viewfinder Coverage
    Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
    Magnification / Angle of View
    Approx. 0.76x / Approx. 35.2 degrees (with 50mm lens at infinity, -1 m) Eye Point
    Approx. 23mm (at -1 m from the eyepiece lens end) Dioptric Adjustment Range
    Approx. -4.0 to + 2.0 m (dpt) Focus Method
    Dual Pixel CMOS AF Shutter Type
    Electronically-controlled focal-plane shutter:
    Electronic first curtain Mechanical shutter Electronic shutter
    Shutter Speeds
    When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb When [Electronic] is set: 1/8000-0.5 sec.
    X-sync Speed
    Mechanical Shutter: 1/200 sec. Elec. 1st-curtain: 1/250 sec.
    Shutter Release
    Soft-touch electromagnetic release Self Timer
    10-sec. delay, 2-sec. delay Monitor Type
    LCD Information
    TFT color, liquid-crystal monitor Monitor Size
    3.0-inch (screen aspect ratio of 3:2)
    2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
    Approx. 1.62 million dots
    Coverage
    Approx. 100% vertically/horizontally Brightness Control
    Manually adjustable to one of seven brightness levels Touch-screen Operation
    Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view
    Coating
    Clear View LCD II
    Anti-smudge coating applied.
    Anti-reflection coating not applied.
    Interface Languages
    29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
    Standards Compliance
    IEEE 802.11b/g/n Transmission Method
    DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n)
    Transition Frequency (Central Frequency)
    2.4 GHz band (5 GHz Wi-Fi not supported) Frequency: 2412 to 2462 MHz
    Channels: 1 to 11 channels Recording Media
    Two SD card slots:
    Compatible with UHS-II
    Eye-Fi cards and Multimedia cards (MMC) are not supported.
    Working Temperature Range
    32 to 104 Degree F (0 to +40 Degree C) Working Humidity Range
    Size & Weight
    85% or less Dimensions (W x H x D)
    Approx. 138 x 97.5 x 88.4mm
    Approx. 680g (including battery, SD memory card; without body cap) Approx. 598g (body only; without battery, card or body cap)
    Source: https://twitter.com/nokishita_c
  • Cripple hammer spotted, "no DCI 4K 24p ALL-I" :p
  • PR
    With anticipation at a fever pitch, Canon U.S.A. Inc., a leader in digital imaging solutions, is excited to introduce the company’s next generation of full-frame mirrorless cameras – the Canon EOS R5 and EOS R6. These groundbreaking cameras are the result of many years of collecting and listening to feedback from Canon users and are sure to meet the needs and demands of a variety of creators. The EOS R5 is a camera designed for professional applications featuring a new 45-megapixel full-frame CMOS sensor and uncropped 8K video recording up to 29.97 fps. The EOS R6 is geared towards advanced amateurs featuring a 20.1-megapixel full-frame CMOS sensor and 4K video recording up to 59.94 fps. The addition of the EOS R5 and the EOS R6 cameras within the EOS R series lineup further solidifies Canon’s commitment to providing the equipment needed for users to bring their content to the next level.
    Canon is also introducing four RF lenses and two RF lens extenders: The Canon RF100-500mm F4.5-7.1 L IS USM, Canon RF600mm F11 IS STM, Canon RF800mm F11 IS STM, and RF85mm F2 MACRO IS STM lenses. All four new lenses were designed to meet the ever-expanding demands of the skilled creatives who capture amazing imagery using EOS R series cameras, including the new EOS R5 and EOS R6. In addition to the lenses, there are two new RF lens extenders, a 1.4x and a 2x model, allowing for users to take their compatible RF lens focal lengths even farther, and a 13-inch professional printer, the imagePROGRAF PRO-300, to bring photos to life through the power of print.
    “For all of the Canon research and development team members who worked tirelessly on the production of these new products, today marks the culmination of a long journey. For those people looking for the next great tools to work with to expand their creative possibilities, the door is now wide open,” said Tatsuro “Tony” Kano, Executive Vice President and General Manager of Canon U.S.A.’s Imaging Technologies & Communications Group. “The industry has asked for new products that can push their levels of creativity to new heights, and we are confident that the EOS R5 and EOS R6, alongside the new lenses, lens extenders, and the pro printer, will fulfill those needs and more.”
    Both the EOS R5 and EOS R6 cameras have the ability to capture the action of a variety of fast-moving subjects with impressive accuracy and speed. When using the mechanical shutter, each can shoot up to 12 fps and up to 20 fps when using the completely silent shutter. Both cameras are the first to be outfitted with Canon's advanced Dual Pixel CMOS AF II which utilizes up to approximately100 percent coverage of the AF area and EOS iTR AF X incorporating AF tracking algorithms using deep learning technology and enhanced readout speed of the CMOS sensor and processing speed thanks to the DIGIC X image processor. The 1,053 automatically selected AF Zones are made even more potent by the ability to detect the human eye, face or head as well as the eye, face or body of animals such as dogs, cats and even birds[i]. Adding to the feature set is the 5-axis In-Body Image Stabilizer, having coordinated control with Optical Image Stabilizer in IS equipped RF lenses. This provides up to 8 stops[ii] of shake correction, a feature that many creators have long asked for from Canon. Both the EOS R5 and R6 cameras come with a new LP-E6NH battery with a higher capacity than the previous model.
    As the new flagship model in the EOS R series lineup, the EOS R5 camera has features that pack a punch for a variety of users who create both still and video content. It has a powerful 45-megapixel full-frame CMOS sensor and is driven by the speedy DIGIC X image processor, giving wide dynamic range as well as boasting an ISO range of 100-51,200 that is expandable up to 102,400[iii]. In a camera full of eye-popping features, one that really stands out is the ability to record uncropped 8K RAW internal video recording up to 29.97 fps and 8K internal video recording up to 29.97 fps in 4:2:2 10-bit Canon Log (H.265)/4:2:2 10-bit HDR PQ (H.265). The camera can also record 4K internal video recording up to 119.88 fps in 4:2:2 10-bit Canon Log (H.265)/4:2:2 10-bit HDR PQ (H.265). External recording in 4K is also available up to 59.94 fps. When in DCI modes, the 8K and 4K video recording is uncropped and Dual Pixel CMOS AF II is available in all 8K and 4K recording modes. Additional features of the EOS R5 camera include:
    • Dual-card slots: 1x CFexpress[iv] and 1x SD UHS-II[v]
    • Built-in 0.5-inch OLED EVF with approximately 5.76 million dots and a 119.88 fps refresh rate[vi]
    • 3.2-inch 2.1 million dots vari-angle LCD touch screen
    • 5GHz/2.4GHz Built-in Wi-Fi®[vii] and Bluetooth[viii] Technology with the ability to utilize the image.canon application, as well as optional WFT-R10A wireless file transmitter with Ethernet support
    • Enhanced operating controls such as rear-dial, multi-controller
    • The ability to voice tag photos and videos
    • Weather, drip and dust sealing on par with the EOS 5D series
    The EOS R6 camera is well-equipped with a host of new features to push the limits of creativity for imaging enthusiasts. The combination of the EOS-1D X Mark III based 20.1-megapixel full-frame CMOS sensor and the DIGIC X image processor produces an ISO range of 100-102,400 and is expandable to 204,800. Internal video recording at 4K is capable up to 59.94 fps or 1080p up to 119.88 fps in 10 bit 4:2:2 Canon Log(H.265) or HDR PQ(H.265). The camera also features a built-in 0.5-inch OLED EVF with approximately 3.69 million dots and a 119.88 fps refresh rate[vi]. Additional features of the EOS R6 camera include:
    • Dual UHS-II SD card slots
    • 3-inch 1.62 million dots vari-angle LCD touch screen
    • 2.4GHz Built-in Wi-Fi®[vii] and Bluetooth Technology[viii] with the ability to utilize the image.canon application
    • Weather, drip and dust sealing on par with the EOS 6D series
    Battery Accessory
    The optional BG-R10 battery grip accessory will be available for both the EOS R5 and EOS R6 full-frame mirrorless cameras. The BG-R10 accommodates up to two batteries and is compatible with the new LP-E6NH, LP-E6N and LP-E6 batteries. The convenient BG-R10 grip accessory can also improve handling for users while capturing portrait photography.
    Pricing and Availability
    The EOS R5 full-frame mirrorless camera is scheduled to be available at the end of July for an estimated retail price of $3899.00 for the body only and $4999.00 for the R5 and RF 24-105mm F4 L IS USM lens kit**.
    The EOS R6 full-frame mirrorless camera is scheduled to be available at the end of August for an estimated retail price of $2499.00 for the body only, $2.899.00 for the R6 and RF 24-105 F4-7.1 IS STM lens kit or $3,599.00 for the R6 and RF 24-105mm F4 L IS USM lens kit**.
    The BG-R10 battery grip accessory and WFT-R10A are both scheduled to be available at the end of July for an estimated retail price of $349.99 and $999.99**, respectively.
  • Overheating times for R6
    • 4К 60p - around 30 minutes before full stop at 23 degrees, down to 20 minutes >30 degrees
    • 4К 30p - around 40 minutes before full stop at 23 degrees, down to 30 minutes >30 degrees
    • Shooting time can be 1/3 of specified if camera is standing open during shooting on open hot sun
  • Is there a source for that? 23 degrees Celsius? I had the impression Mehdia Mehtal was refering to the R5 in the interview. The R5 in 4K30p isn't supposed to have overheating issues. Why then the R6?
    4К 60p - around 30 minutes before full stop at 23 degrees, down to 20 minutes >30 degrees 4К 30p - around 40 minutes before full stop at 23 degrees, down to 30 minutes >30 degrees Shooting time can be 1/3 of specified if camera is standing open during shooting on open hot sun
