Deal from $529
RF version preorder
Photos of RF version
Samyang Expands its RF Series Lineup, Introduces New AF 85mm F1.4 RF
Global optics brand Samyang Optics introduces the AF 85mm F1.4 RF, an autofocus, fast-aperture, short telephoto (portrait) lens for RF mount cameras. This new lens delivers beautiful bokeh, outstanding image quality and impressive autofocusing. Along with the recently launched AF 14mm F2.8 RF, the new Samyang AF 85mm F1.4 RF opens a new door of options to Canon EOS R camera users.
Leading the Market
Samyang is an innovator and has been regularly launching compact and lightweight full frame mirrorless lenses for RF mount. It introduced a series of manual focus lenses, starting with the MF 14mm and MF 85mm models. Then, the world’s first autofocus 14mm lens for RF mount (AF 14mm F2.8 RF) followed in October 2019 and now, the new AF 85mm F1.4 RF is announced, to meet the rising needs and demands of Canon photographers.
Outstanding Image Quality
Samyang lenses are known for their outstanding image quality and this was reinforced by the AF 14mm F2.8 RF being awarded the prestigious TIPA award in 2020 as ‘best mirrorless prime wide-angle lens.’ The new AF 85mm RF also makes no compromise in image quality: A total of 11 elements in 8 groups, with 4 high-refractive (HR) optics and an extra low-dispersion (ED) lens, have been designed to create impressive image quality from corner to corner, even at the maximum wide open aperture of f/1.4.
Smooth and Dreamy Bokeh
Exceptional bokeh is delivered with the know-how of Samyang’s optical designers. The smooth bokeh adds depth and a three dimensional feeling to your portraits. 9 aperture blades provide natural, circular bokeh with a fantastic out-of-focus effect that is pleasing to the eye.
Bright F/1.4 for Treasured Portraits
Shallow depth of focus smoothly blurs the background and highlights the story of the subject. The 85mm focal length, combined with the wide maximum aperture of f/1.4, enables photographers to achieve a dramatically shallow depth-of-field.
Accurate, Silent Autofocusing
A Dual-Linear Sonic Motor (DLSM) works with ultrasonic vibrations, providing high-speed and silent autofocus performance. The accurate high frequency signals, controlled by Samyang’s own protocols, precisely operate the DLSM. Samyang's specialists in optics, mechanical engineering and electronics, have researched co-operatively to produce such effective results for a short telephoto lens. This allows you to capture unforgettable moments easily and quietly.
Enhanced Usability
As well as pioneering new territory, this lens is packed with features: Weather sealing protects the lens from dust, light rain and snow and provides the ability to capture stunning images in less than perfect conditions. Also, the AF/MF switch enables you to be in full control and capture the finest details - enjoy the freedom of photographic expression, with all the latest functions.
- Mount Canon RF
- Aperture Range F1.4 ~ F16
- 11 Elements in 8 Groups, HR 4, ED 1
- Minimum Focusing Distance 0.9m (2.95ft)
- Magnification Ratio x 0.11
- Diaphragm Blades 9
- Filter Size Φ 77mm
- Angle of view Full Frame 28.9˚
- APS-C 19.1˚
- Length 99.5mm
- Weight without Lens Cap, Hood) 582g
- Maximum Diameter Φ 88mm
- Weather Sealing Yes
- AF/MF Mode Switch Yes
- AF Motor DLSM
Rokinon 85mm f/1.4 Auto Focus Lens, $549
Review
Center sharpness is a little disappointing when shooting wide-open at f/1.4, acceptable at f/1.8, and very good from f/2 onwards, with f/16 being adversely affected by diffraction. The edges aren't quite as sharp as the centre, with f/2.8-f/11 producing the sharpest results.
https://www.photographyblog.com/reviews/samyang_af_85mm_f1_4_fe_review/
Samples
https://www.dpreview.com/sample-galleries/8871192793/samyang-rokinon-85mm-f1-4-af-sample-gallery/
New firmware for 85mm AF FE
https://www.samyanglensglobal.com/en/support/support-download.php
@Vitaliy_Kiselev It’s a shame, ‘cause the Samyang’s a gorgeous lens.
One thing to understand, all AF is still just reverse engineering as far as can get this. It is usually hardest if you use AFC as lot of things are very hard to understand if you do not have docs.
