PR
Panasonic is proud to introduce a new interchangeable standard zoom lens, the LUMIX S 20-60mm F3.5-5.6 (S-R2060) based on the L-Mount system for the LUMIX S Series Full-frame Digital Single Lens Mirrorless Camera. Designed for professional use, the LUMIX S Series pursues uncompromising photographic expression with its high-quality cameras and lenses.
The new LUMIX S 20-60mm F3.5-5.6 is a compact, lightweight standard zoom lens that covers from ultra-wide 20mm to standard 60mm focal length for versatile use including landscape photography. The wide viewing angle makes it easier to shoot indoors where space is limited and stunning close-up capability of 5.9 inches / 0.15m (maximum magnification 0.43x) supports still life photography. The new LUMIX S 20-60mm F3.5-5.6 also ensures smooth, high quality video recording because of a mechanism that suppresses focus breathing, which can an issue in interchangeable lenses designed for still image photography.
With 11 elements in 9 groups, the use of 2 aspherical lenses and 3 ED (Extra-low Dispersion) lenses effectively suppresses both axial chromatic aberration and chromatic aberration of magnification. Astigmatism is also corrected with these aspherical lenses, achieving high resolving performance. Furthermore, a UHR (Ultra-High Refractive Index) lens achieves uniform image quality from the center to edges of the image while contributing to downsizing of the lens unit.
With its compact, approximately 12.3 oz / 350g of light weight, the LUMIX S 20-60mm F3.5-5.6 features stunning mobility. The rugged dust/splash-resistant* design withstands use under harsh conditions even at 14°F / -10°C for high mobility. In addition, a fluorine coating on the front element repels water and oil and prevents them from attaching. The filter diameter is 67 mm, with a 9-blade circular aperture diaphragm.
Panasonic and L-Mount system alliance are committed to the development of L-Mount lenses for the further expansion of its lineup to fulfill the needs of end users .
The LUMIX S 20-60mm lens will be available at the end of July for $599.99.
Video with this "kit" lens:
MTF
From product page - https://www.panasonic.com/uk/consumer/cameras-camcorders/lumix-camera-lenses/lumix-s-lenses/s-r2060.html
