E2 and all z cams for that matter are also ideal gimbal camera's Not only because of clearance and mounting friendliness, but because the best case scenario for a gimbal is a balanced cube, not a long thing with the battery off to one side as well as cable mounts. Everying is inline with center of gravity on z cams. With a good pancake or little Olympus 12mm it is only bested in principle by little gimbals with the camera built in and rounded for little wind resistance like osmo's. With the Zcam though you could squeeze two side by side on a large enough gimbal and have a very good relatively small 3d cinema camera. Try doing that with BMP4K/6K.
@markr041....what about the new loupes for the blackmagic? Shoulder rigged would definitely work for run & gun. And yeah slomo is one flaw in the pocket. I believe the gh5 has even higher famerates in 1080. And truthfully have you checked out vegas's new slomo ? Being a still shooter as well, an evf is more than a little useful. I just thru the gh5 in this comparison because they're all about the same price...and I think would be considered by anyone looking at m4/3. Maybe too, the gh5s but it's in another price bracket...and fatally doesn't have stabilization...which for me outweighs the slightly better video specs. Of course, if somebody is shooting a real locked down film with even a minimum crew, then they'd have different agendas. I also , if I was buying one of these, would weigh in the source. Going forward things will change. Which company has the strength to stay and how well are their products protected. I've been a pany user since the gh1. As u remember, i own the original zcam. That didn't taste that sweet, until the hack at least. And even though blackmagic is solid and a beautiful piece of technology, and I bet their v2 will correct at least the stabilization, I'd still put my less than $1500 m4/3 camera choice with pany.
@kurth I agree that IBIS is a powerful feature allowing one to use a much wider variety of lenses, and an evf is useful sometimes. But if you use an OIS lens, you can get adequate stabilization with the Z Cam, so it is a feature lack that can be overcome. But you cannot get 4K 120P+ from the GH5. Of course, that is a specialized feature. I also think the color science of the Z Cam and the Pocket 4K is visibly better than that from the GH5 and there are better codec options. The Z Cam and the Pocket 4K use the same sensor as the GH5s, which is a better sensor in many ways for video (and the GH5s has no IBIS). The GH5 is much easier to use, requiring no rigging - it is a complete camera with excellent video output. My main comparison is with the Pocket 4K and the Z Cam, where I think the former is unuseable by itself for handheld work, and offers less shooting options than the Z Cam (4K 120P+ again!).
I think the biggest difference is that you can shoot with high frame rates in 4K - up to 160P - with the E2-M4. There is no camera that can do that - 120P C4K with no crop and no time limit - for less than some large amount of money and bulk. In 10bit color. Internally.
Also the big lcd on the BMPCC4K is useless for handheld shooting because it is at a fixed angle. You need a monitor anyway, in which case it is a big ugly thing. Battery life with its single battery is terrible, so you need to bulk it up even more with some kind of battery pack. No auto ISO. Just useless for run and gun.
Biggest difference for now is much more open and accessible team behind E2.
Plus camera is much more modular and firwmare updates can be actually discussed with them.
BMPCC is more polished.
That price difference is so close now between E2-M4 vs P4K!
Big slashes of prices across the board too, except the E2C also don't get a price drop :-/ A pity, if it had got say a 25% drop then at $599 it could be tempting for me against the Panasonic G85. But for now, I personally would take the IBIS and ease of use over a box with the GH4 sensor and internal 4K 10bit
