14mm F2.8 MK2 Samyang MF - famous MF wide lens update
    • 14 Elements in 10 Groups, 1 ASP, 1 Hybrid ASP, 1 ED, 3 HR
    • Aperture Range F2.8 ~ 22
    • UMC Coating
    • Minimum Focusing Distance 0.28m (0.92ft)
    • Magnification Ratio X 0.08
    • Diaphragm Blades 9
    • Filter Size (mm) None (due to built-in lenshood)
    • Maximum Diameter(mm) Φ 87.0
    • Mounts - CANON, NIKON, SONY E, FUJI X, CANON M, MFT
    • Length (mm) 96.1 96.3 122.1 122.4 122 120.9
    • Weight (g) 649g 641g 708g 694g 695g 692g
    • Retail UK prices ranging from £359 to £439, depending on model and fitting
    • US price $99
  • 4 Replies sorted by
  • Scheme
    MTF
    424 x 434 - 20K
    461 x 523 - 25K
    462 x 663 - 33K
  • PR
    SAMYANG Announces Mk2 Versions of Legendary Manual Focus Lenses for full frame DSLRs: NEW MF 14mm F2.8 Mk2 and MF 85mm F1.4 Mk2
    May 25th 2020, Seoul, South Korea - Samyang Optics Co., Ltd., a leading global optics manufacturer, announces the long-awaited renewal of two classic and respected manual focus lenses for full Frame DSLRs: The new MF 14mm F2.8 Mk2 and MF 85mm F1.4 Mk2 lenses will be available in 6 different mounts as follows: Canon EF, Nikon F, Sony E, Fujifilm X, Canon M and MFT.
    The Samyang MF 14mm F2.8 Mk2 is an ultra-wide-angle, manual-focus lens with superb sharpness from corner to corner, even at its maximum wide-open aperture. The 115.7˚ wide angle of view is ideal for shooting landscapes, interiors, astro-photography etc. and the attached lens hood effectively blocks unwanted light so you can shoot as you wish.
    What’s New? - Main Features
    Focus Lock & De-click Aperture Option
    The MF 14mm F2.8 Mk2 includes two completely new features: “Focus Lock” & “De-click”. Now you can lock the focus ring at a specific point, greatly improving precision and repeatability, especially useful in astrophotography and time-lapse shots. The de-clicked aperture option allows infinitely fine adjustment between F-stops. By rotating the silver ring from 'Click' to 'Free', you can adjust the aperture smoothly and precisely, to ensure exactly the right amount of light is captured.
    Beautiful Bokeh - 9 Aperture Blades
    In terms of bokeh performance, the 9-rounded aperture blades help to achieve excellent smooth and creamy out of focus backgrounds. The 9 aperture blades also provide clearly defined sunstars when the aperture is stopped-down.
    Exterior Design
    The MF 14mm F2.8 Mk2 has a consistent and balanced exterior design of body and lenshood. There is also a new micro-pattern texture on the rubber focus ring which provides comfortable, positive handling.
    Creative Expression with Ultra Wide-Angle of View (115.7˚)
    With a minimum focusing distance of just 0.28m (0.92ft) and its 115.7˚ angle of view, this lens allows users to create compositions that emphasize dramatic perspective that is unique to ultra-wide-angle lenses.
    14 Elements in 10 Groups (1 ASP, 1 Hybrid ASP, 1 ED, 3 HR) with UMC
    The MF 14mm F2.8 Mk2 features a total of 14 elements in 10 groups. These include 3 High Refractive, 1 Hybrid Aspherical, 1 Aspherical and 2 Extra-low Dispersion elements. The special optical design adjusts the light path through the lens for clear and vibrant images and also corrects chromatic aberration.
    Usability / Weather sealing
    Environmental seals are located around the lens mount area to prevent infiltration of moisture and/or rain drops. This feature provides an additional layer of protection when shooting outdoors under adverse weather conditions.
