AMD B550 based motherboards
  • 4 Replies sorted by
  • ASRock
    ASRock B550 Taichi incorporates 16 phases of the latest Dr.MOS VRMs, providing a superior power design that can handle even the highest performance Ryzen desktop processor, even when overclocking. With large, passive heatsinks and 2oz Copper PCB foundation, it keeps temperatures lower, the system is more stable and improves energy efficiency.
    PG Velocita is a brand new high end product line under the Phantom Gaming family, the B550 PG Velocita motherboard packed full with uncompromised performance as well as relentless appearance. "Velocità" is Italian for "Velocity", destined to give a fast and unbeatable gaming experience to the gamers
    800 x 557 - 94K
    800 x 514 - 88K
    800 x 525 - 92K
    800 x 474 - 93K
    800 x 469 - 83K
  • Gigabyte
    800 x 568 - 92K
    800 x 563 - 90K
  • MSI
    MPG B550 GAMING CARBON WIFI
    MPG B550 GAMING CARBON WIFI is inspired by supercars concept with a slick look and feel. An aggressive 12+2+1 VRM power with doubler design ensures perfect power delivery for high performance. Enhanced thermal solution including Aluminium Cover with additional choke thermal pad rated for 7W/mk, 6 layers PCB with 2oz thickened copper, and two M.2 Shield Frozr all designed for better heat dissipation. 2.5G LAN and Wi-Fi 6 AX solution provide faster wired and wireless network connection and other advanced technology such as Pre-installed I/O Shielding, Front Type-C and Flash BIOS Button improved efficiency for better gaming experience.
    MAG B550 TOMAHAWK
    The military totem style shows rigid and stable design. MAG B550 TOMAHAWK offers essential specifications and features for the mainstream gaming PC market. Dual LAN including 2.5G LAN and Gigabit LAN provides both faster intranet and internet experience. Extended Heatsink Design, 2x M.2 Shield Frozr and PCB with 2oz thickened copper all enhance heat dissipation effect. Other features including Flash BIOS Button, Pre-installed I/O Shielding and Front Type-C all provide more convenience for gamers.
    PRO series provides users a smarter working environment. B550-A PRO supports Lightning Gen 4 solution for both PCIe and M.2 slot. Featuring 10+2+1 Digital PWM with Duet Rail Power System for stable power delivery. Extended Heatsink Design, M.2 Shield Frozr and PCB with 2oz thickened copper are essential for better thermal effect.
    800 x 645 - 87K
    800 x 646 - 99K
    800 x 621 - 68K
  • ASUS
    ROG Strix B550-E Gaming
    ASUS built ROG Strix B550-E Gaming with an eye towards AMD's high-performance processors and dual or triple expansion card setups. The AM4 socket is flanked by a 14+2 power stage VRM for reliable performance under sustained loads from many-core CPUs, while reinforced PCIe x16 SafeSlots support multi-GPU action in two-way SLI or three-way CrossFireX setups for gamers and creators alike.
    Strix B550-E Gaming's six fan headers and dedicated AIO and pump headers allow for setups as simple or intricate as a given build requires. Q-Fan software controls with automatic fan-speed detection and multiple presets make it easy to keep both temperatures and noise levels down. Dual M.2 slots can take in SSDs up to 110 mm long, both covered by heatsinks to prevent thermal throttling under intense I/O loads. Strix B550-E Gaming also features an Intel-powered 2.5 Gbps Ethernet and WiFi 6 controllers, Bluetooth 5.1 support is on tap for wireless headsets, phones and tablets.
    USB connectivity is particularly plentiful on Strix B550-E: it includes three USB 3.2 Gen 2 connectors (one Type-C and two Type-A), along with a smattering of USB 3.2 Gen 1 and USB 2.0 ports. ASUS has included a USB 3.2 Gen 2 front-panel connector for the latest crop of cases.
    The high-end SupremeFX S1220A audio chip comes with a handy companion in the form of a USB-C Audio port for auto-detection of the device signal type, so the port can be used for both Type-C audio devices and standard USB connectivity as needed.
    A total of four RGB headers are available — two standard headers and two Gen 2 addressable hook-ups with individual LED control, reduced latency and automatic configuration support. All those diodes can be turned off with one click to give the board a stealthy black-ops look. Additional touches include BIOS FlashBack for updating firmware without a CPU and FlexKey reset button remapping.
    ROG Strix B550-F Gaming (Wi-Fi)
    ROG Strix B550-F Gaming (Wi-Fi) proves the point for builders who want a performance-oriented board with a healthy dose of luxury. The 12+2 power stage VRM is ready for top Ryzen chips, and 8+4-pin ProCool auxiliary power connectors with solid pins ensure steady and stable power delivery to those power stages.
    This model includes Intel I255-V 2.5 Gbps Ethernet connectivity and WiFi 6 support from an Intel AX200 adapter, while the pristine SupremeFX S1220A codec makes an encore for superior audio experiences.
    Strix B550-F Gaming (Wi-Fi) follows the distinctive visual standard of the ROG Strix family and looks plenty sharp on its own thanks to the eye-catching ROG eye logo and recessed cybertext patterning, and an integrated I/O shield. For customization, a user can add plenty of lights with RGB LED strip headers in both regular and Gen 2 addressable flavors - all with Aura Sync support for easy configuration.
    ASUS TUF Gaming B550-Plus
    ASUS TUF Gaming B550-Plus features 8+2 DrMOS voltage regulator module and the multiple generously-sized heatsinks atop the VRM, chipset and M.2 slots ensure all primary components stay cool under load. The main PCIe 4.0 x16 slot is backed by SafeSlot reinforcement for extra-heavy graphics cards, while a ProCool auxiliary connector with solid-core pins offers added peace of mind when using power-hungry CPUs.
    The two M.2 slots both accept devices as long as 110 mm, while the duet of PCIe x16 slots supports CrossFireX configurations. The rear panel includes USB ports of every modern type, and that loadout can be further expanded with Thunderbolt 3 connectivity thanks to an onboard header. A BIOS FlashBack button rests near one of the ports for CPU-less UEFI upgrades.
    TUF Gaming B550-Plus comes with 2.5 Gbps Ethernet connectivity and there's an M.2 E-key slot available for a WiFi 6 and Bluetooth 5.1 upgrade. The Realtek S1200A audio codec in this model is further enhanced by DTS Custom support for headset 3D surround-sound virtualization, making movies and compatible games come alive with pinpoint-accurate positional audio.
    The gray-and-black TUF Gaming aesthetic and its yellow accents is distinctive on its own, but this color palette also makes for a great canvas for additional lighting. A Gen 2 addressable RGB LED header and two standard headers can be wired to additional strips for easy visual customization.
    691 x 861 - 135K
    693 x 851 - 134K
    693 x 812 - 154K
