Topic dedicated only to compact and useful info on selecting proper SSD drive.
Note - use our deals topic after reading posts below to save as much as possible on new SSD.
One thing I suggest is to look around for good used Thinkpads (if you need note). Lot of them being sold out from corporations.
Thing is this is literally old crap that was laying arround. It was the best crap I could put my hands on. I have my computer for when this thing don't work. And guess what, new work law tell that the gear to work from home may be totally your own problem.
Will try to get some fun tweaking this little old guy.
Your works guys are not generous :-) At the time SATA 500Gb SSDs are $50-70 :-)
Got a note with 500gb HDD and 32gb SSD from work. Going to do a tiered pool as per this guys article, as it shows significant benefits to random writes. Objective will be some light video and photo editing.
https://nils.schimmelmann.us/post/153541254987/intel-smart-response-technology-vs-windows-10
External NVME USB 3.1 boxes performance
It is two main chipsets for doing such boxes - ASMedia ASM2362 and JMicron JMS583.
Large file writing speed
Large file reading speed
Enterprise SSD specifics
This is U.2 version, being much larger than M.2 it can be up to 8TB with 8 BGA NAND chips.
If you look at photo you see many tantalum capacitors, they are present to allow controller to properly finish any remaining operations and gracefully close all stuff without data corruption.
Placing proper capacitors and making controlled work the same is quite cheap but is usually never done on consumer models as manufacturers do not care if you will loose all your data after power failure.
Good tip on selecting M.2 PCIe SSD size
Let's get cheap, but quite good Chinese drive as sample.
This drive has 4 sizes
For any given controller you must look at models using all four chip places, usually it is largest size model, but can be other options. Still largest size model usually is fastest.
Smaller sizes model can be from 1.5x to 4x slower during large sustained write and also slower during sustained read.
Manufacturer speed table (it is SLC cache mode speed!) for previous version that used smaller capacity chips. newer version must be slower for same capacity (except new 1TB capacity).
New SSD models tricks
Here we will get ADATA XPG SX8200 Pro as example.
SSD has special controlled firmware aimed at getting good benchmark results.
Idea is simple - SLC cache (see above about it) is not flushed as usual, but is held for really long time. So, benchmark that works with limited size of data will be measuring SLC SSD drive :-). As even all reading will be done in SLC mode because of so long cache hold time.
Smart cheating.
Also remember - most sites tests are horrible shit that aims at low volume operations and running few benchmarks only without fully understanding that it all means.
AMD HEDT Platform Limits
Threadripper TR4 x399 platform is definitely best among competition in IO lines and storage capabilities.
Check diagram above.
You can connect really lot of stuff.
Only issue remains the x399 chipset that is actually almost same as x370/x470 consumer one.
All shortages come due to fact that inside Threadripper is basically 2x Ryzen chips.
Playing with Meltdown and Spectre patches for small performance increase
https://www.grc.com/inspectre.htm
You can use this tool to remove some performance hit to CPU and SSD made by changed OS behavior.
Largest improvement will be on older Windows 7 and Windows 8, and for fastest drive in case of random read tasks.
It is pretty safe thing to do, just do not do it on company computers or on places that have lot of third party documents and new questionable software installs.
AMD Ryzen consumer platform limits
All consumer AMD CPUs are vastly limited in IO lines available - CPUs without GPU have total of 24 PCIe 3.0 lines only, and ones with GPU have 8 less.
If you use X370/X470 AMD chipset motherboard you have abilities as shown on the diagram above.
Note that AMD chipsets have much more limited abilities as it has only PCIe 2.0 lines and very few of them, and they are used for all features, including network, frequently USB 3.1 and much more.
Also AMD CPUs can split x16 only into x8/x8 and not x8/x4/x4 like Intel. But instead they have 4 extra PCIe lines intended for NVMe SSD drive. Due to this 10Gbit network make less sense in AMD case.
Planning to have fast Infiniband network card you can have only one NVMe SSD connected directly to CPU.
Most motherboards will have only one extra M.2 connector that is connected to chipset and uses slower PCIe 2.0 lines, some boards even have only SATA or x2 lines at this connector due to real shortage of PCIe lines.
Make sure to check our AM4 motherboard selection guide.
Further you usually can connect only extra SATA drives using controller build in chipset, note that many additional external controllers present on some motherboards can be slower (in SSD case only, they are fine for HDD).
Timely topic with useful info. Thanks!
Intel consumer platforms limits
All consumer Intel CPUs are vastly limited in IO lines available - they have total of 20 PCIe 3.0 lines only.
If you use good top Z chipset motherboard you have abilities as shown on the diagram above.
Planning to have fast 10Gbit network card you can have only one NVMe SSD connected directly to CPU.
If you plan to use even better Infiniband card that requires x8 slot you won't be able to connect any NVMe SSDs directly to CPU unless you plan to use GPU build into CPU.
All other M.2 slots will be connected to chipset, issue here is that any copy speed between them will slower due to CPU-Chipset link becoming bottleneck.
Throttling due to high controller temperatures
Big speed reduction due to thermal throttling is very actual thing in video editing tasks.
As soon as you start dumping hundreds of gigabytes to your NVMe drive you can run into lot of issues.
The better is your SSD drive - the more important is cooling.
Especially important if you plan to use our cheap Infiniband approach.
This is that throttling is doing:
If you write large volume of data at once you need to install good cooler:
And, no, M.2 Shield or similar called shit is not good cooler, it can make things even worse:
This is better:
And this one is good:
Learning to read and understand benchmark results
CrystalDiskMark
Manufacturers usually advertise big "Seq Q32T1" numbers, but they never happen in nature until you run highly optimized copy software doing lot of parallel copies of very large files. The higher bitrate are in your video files - the more such numbers will affect performance, especially true with RED raw and Cinema DNG - for them they are important.
If you are editing H.264/HEVC 50-200Mbut files and use lot of other smaller files in projects you need to look more on "4K Q1T1" number. It can be pretty unimpressive, but it is one that will define real drive performance in your case.
Most code reading video files from disk in Premiere, DaVinci and other editors is badly optimized for modern SSDs. In many editors it is licensed code, they do not know how it works even in details.
Small trick
Most testers will use small test size (1-7GB). Due to algorithms SSD controllers work you can get very nice performance in this bounds. But as soon as you start real use with big amount of data - you will be utterly disappointed, or if you use SSD in the recorder - recording can even stop and ruin all your day.
HD Tune Pro
Our interest lies in the graph of writing speed over time.
SSD write caching
Almost all SSD controllers have special cache. Some of them can use almost all free disk space as cache also. What it means? Controller will treat each single TLC cell as SLC cell, so it will store 3x less information than usual (if other memory type is used - it will change accordingly). Such writes are very fast, but later in time controller will need to compact all data properly. During compacting process performance (even reading!) can degrade a lot.
Remember! Size of cache can dynamically reduce as you fill up your SSD with data.
WD Green SSD as sample of very low cache and really bad write speeds.
Especially nasty such graph can be in case of QLC memory:
As you bring lot of video footage and start dumping it to your new shiny fast SSD you can quickly get in situation where write speed will be same or even slower than HDD.
Tip. If you select SSD for recorder, as your main editing drive or it is place where lot of footage will be regularly transferred - you need to look on SSD that can keep same speed outside cache or drop it only a little.
More samples of sustained write speed for 1TB NVMe SSDs
Optane memory
Post dedicated only to Intel Optane memory based solutions.
See https://www.personal-view.com/talks/discussion/21389/optane-for-video-editing-specifically-900p-280g-#Item_5 for now.
Various NAND memory used in SSD Storage
Electrons per one level difference
Types of memory you can find in SSD sorted by frequency (at present time):
Various kinds and interfaces of SSD drives
Main categories
